Need help Check engine and Traction is on
11-15-20 | 12:38 PM
How you doing guys.
I need help on my 2011 Lexus ISF Check engine and traction is on( see in picture) and Do you have any IDeas what it should be?
11-15-20 | 01:42 PM
Quote:
Originally Posted by
Davidison
How you doing guys.
So at the risk of being obvious, you have a check engine light, you will need to have it checked with techstream or you can have it checked at autozone.
11-15-20 | 02:26 PM
Assuming you're 100% stock ???
If not list all your performance mods...
Also as suggested, take a trip to local autozone to have the code(s) read for free...
Joe Z
11-15-20 | 06:03 PM
Get the code read. The car defaults to traction off whenever there is a fault code. Mine did it with an exhaust leak.
11-16-20 | 02:14 PM
any luck with getting the codes read?
11-26-20 | 09:08 AM
Finally resolved
oxygen sensor need to be replaced by new one.
I have replaced with used one and had same issue and now i bought new one and fixed 👍👍👍👍
11-26-20 | 11:10 AM
Davidison
Finally resolved
How did you do it ???
Code read... Shop... DIY..??
Joe Z
pcolache
ES - 5th Gen (2007-2012)
12
05-12-14 07:19 PM
trinituner
04-12-09 01:18 PM
Shijir
Performance & Maintenance
01-11-07 05:15 PM
