Error P0365
#31
Bank 2 complete.
Note : #2, #6, #8 had oil in the spark plug tubes. Cleaned tubes. New Coils in #2 & #8
Due to soaking in oil, the rubber boot on the tip of coil 2 & 8 was loose.
#6 Plug
Cleaning Plug Tubes.
Inside Plug tube 8
Bank 1 today & hopefully start up later today.
#6 Plug
Inside Plug tube 8
#34
All Plugs replaced , no real difference.
Coil Replaced on #8
Error Logs report misfire on cylinder #1, #2, #3, #5, #7
Before replacing plugs misfire #2 & #8
Error Code is P0365 - Cam Sensor Bank 1 exhaust has been replaced.
Dark now, will check connections in the morning.
Coil Replaced on #8
#35
Tech Info Resource
Have you done a basic health check? Either compression test or leakdown test? That #6 plug looks really bad.
#36
Compression test on TIS, #2 @ 8% lower.
Not sure what the tolerance should be.
Will investigate fuel / injectors as motor sounds like 5 cylinders running.
results from TIS compression test. AVG is 166 , lowest is #2 at -8%
#37
Tech Info Resource
None of those numbers look like what I would expect from our compression ratio. Throttle blade was wide open for the test?
#38
This is on a cold engine / car does not run for more than 5 seconds.
I saw your video re: chain tensioner, when the car turns over it sounds similar or worse. Metalic rattle plus misfire
I think the next step is to remove the valve cover and check the timing. Fingers crossed that the timing chain / tensioners / valves are ok.
#39
Update .
Mechanic diagnosed issue as broken chain. He put a camera into the cam sensor hole and saw the cam was not moving.
We are looking for a replacement engine.
#40
Tech Info Resource
...wow! Sorry about that news....any idea how the chain would snap on this motor as you don't hear of that very often at all on the 2UR-GSE any ideas?
#43
Not sure, potential some red flags,
1. 10 days before I had a metallic noise & a sulphur smell at high rpm - at the time I thought maybe headers - should have got it tested..
2. the same day, there was a "wheel bearing" type noise for 2-3 seconds @ 40kmph 1.5-2k rpm. - appeared to disappear when moving the steering wheel
3. at t=0 car was at idle at junction. - engine stopped with a metallic noise. sounded like something let go.
I know valve inspection was not done. maybe should have & it could picked issue up earlier.
MileHIFcar (02-11-21)
#45
That's so weird that your chain snapped😢😣😬........what are you going to do, replace the engine with another or just rebuild the motor?
