Tires
Theoretically, your proposed wheel is 19mm wider on each side but your new offset will bring it in 20mm so the face of wheel will sit 1mm in more. So if your current setup rubs, chances are your new setup will rub at least the same amount, but likely even more since your new tire will be taller.
Will the taller part of the tire not "tuck" under the fender?
I'm trying to calculate my old set-up but it might have been -22 which would make my new set-up about 4mm more inboard from the fender. Thanks in advance!
To the OP.
I am running 255/35/19 Front and 275/35/19 Rear and I was not rubbing while stock height. You should be fine.
