Brembo caliper technical drawing / specs?
Hi, Not a Lexus owner (long time Toyota owner!). I've been looking for some calipers to fit to a build I'm working on for a '90s Japanese domestic vehicle. I've been struggling to find something substantial that I can make an adapter for to mount to the stock hub/knuckle mounting ears. I came across the ISF Brembo calipers (front) and am very interested due to how the mounting lugs are staggered/offset and with a decent portion between them with space. They look like they are ideal candidates to try for my goals.
I've been watching and searching for a single front to come up at a reasonable price, alas nothing since I've been looking. Are there any technical drawings for these calipers? If not any details on some measurements: height, width, depth, spacing of the mounting ears/lugs, offset between the top and bottom mounting location.
Many thanks for any help, I'm trying to stop an old rotary barge with additional power.
Rgds, Ant
Rgds, Ant
antaenc (12-17-20)
Something like that would be perfect! If not available for the OEM Brembo I can model the approx dimensions and 3D print to test fit on my bench suspension/knuckle mock up. I'm specifically interested in the front OEM caliper as attached. I'm confident the matching rears will work - if the fronts work out I'd be ecstatic.
OEM Brembo (Front)
OEM Brembo (Front)
I took some pictures for you. Apologies, I don't have any measuring calipers big enough so can't measure accurately so I just lined things up with a ruler to give you a rough idea. Not sure what specific measurements you need but let me know if you need anything in particular.
Also, I have a busted front right caliper from a failed caliper painting project (long story) that you might be interested in. I threaded the brake line fitting whilst reattaching it and then also managed to fubar the helicoil attempt. Ended up buying a new caliper. I suspect it could be repaired by filling the hole with weld or something and re-drilling the hole. Either way, gives you something that you could work with for your measurements. PM me if you want to make an offer--note that I am in Australia and you'll need to cover the shipping cost.
For the below:
- Center between each mounting ear
- Center of lower mounting ear to low point in the curve between mounting ears
- Center of upper mounting ear to low point in the curve between mounting ears
For the below, how wide the mating surfaces are both mounting ears
I think every other measurement I can scale and work out from the original pictures you sent.
Thank you for the offer of the caliper, I'm in the US, shipping might be horrid :-( If you were gracious enough for the above requested new measurements I should be able to print a 3D mock up of the approx key dimensions to test mounting which would be a massive step forward for my application and enough to buy a complete set of front and rears to start real fabrication work. I cannot thank you enough, I'll PM you about funding a few beers/coffees.
Cheers, Ant
EDouble79
08-25-11 10:01 AM
