ISF wheels and stock suspension
Hi all,
Does anyone have any idea what the limits are on what width/offset wheels you can run on the F with stock suspension (and without modifying the arch)?
I was looking at some Work M8R in 8.5" 38 and 9.5" 38, they would stick out 13.4mm more at the front and 23.4mm more at the rear.
Thanks,
Thanks,
Tech Info Resource
I am currently struggling with 275/35/19 Michelin PS4S on 19x9.5 51ET OEM wheels rubbing on one side. Your tire selection will impact this decision, but I seriously doubt you'll be able to put wide tires on those wheels and not rub.
Received 1,063 Likes
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
See below... Clears perfectly fine on my 2012 wheels and 275/35
I didn't waste my time with heating & rolling..
I shaved / grinded off the excess metal and used a few layers of touch paint to seal it up..
Looks & feels like OEM
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
Originally Posted by Joe Z
I had some nice tire rubbing/cutting going on, with stock suspension on my IS-F
With this Rear set up:
19x9.5 w/ 35mm offset on a 265-30 Yokohama Advan Sport tire
Solved via DIY ..
Joe Z
PJSnow (09-13-21)
I can’t help but feel like I just saw photos of JoeZ clubbing a baby seal
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Thanks guys.
I had been hoping I could get away without any modifications to the arch/etc as it's the least extreme offset available for the wheel, oh well.
I guess nearly 2.5CM wider than stock is just too much though, shame.
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/343x561/untitled_18a3d69015fdd62f377e91abf90db716b08f6563.png)
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1307/69927806_faf2_4715_9682_15ff166f6015_1aa1e5e0b8f10d2f4cdc6ada0bc12926f1706261.jpeg)
Rears: 9” wheel w/15mm spacers~ +40 offset on 275/30-19’s. No rubbing.
Fronts: 8” wheel w/ 15mm spacer ~ +30 offset on 245/35-19.
Stock suspension
THE350
08-04-13 09:05 PM
