18" TRACK wheels and tires recommedation
im planing on buying a set of track wheels and tires. i loved the A052 Advan, but was wondering if i could use 8¨wheels, it seems that the enkei tunning line only comes in 8. so was wondering if i could try a 275 40 18 on a 8" 45 offset wheel for the back and the same 8" 45 offeset wheel for the front but with a 245/40 tire?
Nikeboi09 (10-08-21)
^^ +1 on that. 8 inch wide of a rim on all 4? Correct me if I'm wrong, but you will be the first I know off to try this combo here. I recommend what vervish stated. 18x9.5 +45 offset with 275 35 18 tires works really well. I'm also on WedsSport SA-20R wheels and they had been very good. Although I don't track my car, it really feels good around the corners.
Tech Info Resource
RJMacReady (05-02-24)
hi Lobuxracer, long time not chating.... are you refering that what is too small the 18" or the 8" width or the 45 on front or the 275 on the back?
Thanks pal
JP
Thanks pal
JP
8 inch wide is way, way too narrow for a track wheel on this platform. It is simply too heavy. You want 18x9.5 et 45 on all 4 corners, and with 275/35/18 tires on all 4 corners. This is a time tested and heavily vetted / successful track standard for these cars. Some have ran et 38 as well.
lobuxracer (10-08-21)
Tech Info Resource
Would you use a square setup? all corners with 275?
JP
Tech Info Resource
remember im in a. second world country, so getting the right stuff is complicarted, but at the end my local shop order four enkei racing RPF-1 in 9.5. that rear tires are ok at 275.35.18, but he did order 245.40 for the front.
JP
JP
JP
JP
Intellexual
Wheels and Tires Classifieds
01-11-10 07:29 PM
TOMLEXUS
43
08-08-05 01:40 PM
