New ISF owner- questions.
Hi all!
Im a new ISF owner and recently bought a 2008 model with 65000 miles on it.
i might add that all my driving has been in around 0-3 degrees celsius (35 degrees fahrenheit).
Thank you for any help!
- I took it for a short spin the other day (not driven much at all since it is freezing and going wintertime.) but i noticed that after heating it up i did a full throttle pull in sport mode with the shifter in manual mode, at about 5800 rpm i went to upshift but the car didn't respond and stayed in 3rd. This has happend on a few occations when i go to upshift it does not respond. Downshifting is always fine. So im wondering if your ISF always responds to the paddles in manual mode or if the car can sometimes miss shifts?
- Another thing i also noticed when testing the car was that the ABS was very aggressive, this was on close to freezing temperature. iv driven alot of performacecars before and i know what ABS engagement can feel like but on my ISF it was like it was acting uneven and shook the steeringwheel quite aggressively.
Congrats on new ride.
I have not experienced any sort of shifting issues with mine. Considering it is only on the upshift, it might be that the paddle shifter module (on the steering wheel) iis not working correctly? Have you tried shifting from the shifter in the center counsel?
When ABS kicks in you can feel it, but it is similar to other cars I have driven...even on summer tires in cold weather.
Hi all!
Second issue may be the same but just cold tires. If you're on summers or even all seasons and they're not warmed up in >40 F degree weather, you may be loosing traction and the ABS starts cutting it.
WhyHateTho (12-02-21)
Hi all!
I8ABMR
GS F (2016-present)
06-27-17 02:31 PM
