Navi screen out
Navi screen out
My screen is done and I’m living with it ok until my wife got in and adjusted her temp. Now the dual is locked in and adjusting two different temps surpasses my first world problem limit.
I’ve unplugged the battery and it didn’t reset. Though, all my saved presets did making my steering adjusting obsolete 😅
Do any of those OB2 plug ins give control of the dual temp?
Any suggestions until I can take the system to a local place and have it fixed. They said 300$ ish btw.
Thanks
Thanks
Quadrphnia (05-07-22)
Could you give some more details about what you did? I've done apples/androids phones/tablets and would appreciate any specifics you've got on this one. I anticipate this happening to all of us eventually.
here you go.. search thread is your best friend.. I fixed mine 5 years ago following these steps..
https://www.clublexus.com/forums/is-...n-fix-diy.html
footballpl (05-08-22)
Yes, it's easier for sure, but obviously it's more expensive.
the whole screen is the digitizer itself.. you replace the whole thing.. just make sure you get one that does not have a rainbow reflection on the screen. some have them and can be seen on certain angles..
As far as I'm tracking, most were replacing the digitizer itself because it's cheaper. I saw some DIYs where they were separating the digitizer from the LCD screen, gluing the new digitizer on over the original LCD and resoldering just that one ribbon cable. Another reason why I can find two separate parts as one with the LCD fully assembled w/digitizer and the other is the cheaper option with just the digitizer itself. I've always read like you mentioned the rainbow coating or whatever with some replacements.
I'm trying to understand this. The digitizer can be replaced as its own unit.
I did it myself a couple of years ago but I found that the aftermarket replacement screen was dull, not as transparent, and isn't fingerprint resistant as the OEM one.
With that being said, it was nice to have accurate touch points again.
Until it stopped. It got to the point where the screen would only register ONE touch at each start up.
Then it got really inconsistent...
Then it was only giving screen touches IF the car was cold (I'm talking about winter ~30*F) before the HVAC would warm up the car and the screen would be useless.
I broke it out of frustration (pushed too hard) and I'm back on the original digitizer again (Good thing I kept it).
I keep seeing people mention using a silver pen to relay some conductive material but idk where they're doing it.
I still have this issue where the top of the screen is accurate but the further you go down, the more inaccurate it got (if you pressed at the very bottom, let's say 100%, it'd only register whatever is 20% before it. 50% would mean it would give ~10% right above where you touched it)
it's possible in some cases to repair the connection on the ribbon cable with a conductive pen, I did it on my sisters 07 IS250. Here's the thread for that procedure Frozen Navigation Screen Fix DIY - ClubLexus - Lexus Forum Discussion
I'm assuming the OP has resolved the issue, but posting for future members who encounter. I did this repair myself in 2022, and I'm pretty average in terms of being "handy". I found this youtube video and followed it exactly.
Getting prepped and staying organized was key. Watched the video several times. Kept all my screws in labelled containers - re-watched the video again mid-project.
Initially, I was concerned I would do all this work and it wouldn't fix the issue, but it works well now.
The following 3 users liked this post by Lushman:
see, my concern is that while the screen works, the accuracy is still off.
Towards the top, 100% accurate.
By the time you get to the bottom of the screen, you can't touch the AC button or confirm a different audio player.
