2011 Lexus ISF limp mode
10th Gear
Hey what’s up
I recently purchased a 2011 Lexus ISF, 75,000 miles. Love the car, drove fine until recently it feels like the power is cut. Like a limp mode
Basically before I could pedal to the metal and the car would go thru it’s gears nicely and shifted quick.
now it feels like when I punch the car, once it hits 5000 rpm’s it goes up so slowly and the engine kind of mutes itself. The car still drives but it’s a very weak acceleration. I don’t have a check engine light, no codes pop up. I clean my maf , I got a new intake. I cleaned my throttle body and I reset the ecu. Still have the same problem
has anyone had this, or does anyone maybe know what else I could check ?
It's bad fuel. I've had it happen few times, always after I had to get fuel from some no name station in a middle of nowhere. Burn it off, get new fuel, and things go back to normal.
Yup...Like Marcin said. Its bad gas.... You gonna have to burn it off (I would not add any additives) probably sooner than later just so I could refill it sooner with much better gas.... I highly recommend you try a different gas station then the one you filled up at. I have great luck with BP or Shell.
10th Gear
But then ever since then I’ve only been filling up at shell and the ISF currently has shell premium.
Any guesses on what else it could be? Maybe injectors or fuel pump?
Idk the maintenance status of your ISF in terms of injectors or fuel pump etc, but I would generally steer away from any and ALL Grocery or Store Chain "gas stations". That said, it is possible that a Shell station had "bad gas" regardless of Octane number. That did happen to me once and it was also Shell and it only happened once about 9 years ago in my X5. I continued to use Shell after that with no bad gas incident again. I've never had bad gas with BP though, ever... And now if possible I specifically look for BP when filling for gas.
10th Gear
10th Gear
also one of my mechanics said maybe it’s clogged cats, should I take ‘em off see what happens?
10th Gear
If I recall correctly, I was in manual mode. From a complete stop I would shift from 1st into 2nd & would immediately notice the rpm’s hanging in there longer than usual. Once I shifted into 3rd redlining it. The car would jolt a bit & it would go into limp mode. Starting me out in 2nd gear. I would disconnect battery & reset. It kept doing it, unless I drove normally. The Valley plate was recently resealed & spark plugs. I took back to the mechanic & switched to OEM plugs. I can’t remember the plug model but it was NGK plugs. I didn’t have issues after.
I’ll switch out my plugs then too, and while I’m at it my injectors. I’ll keep ya updated !! Thank you
I'd DEFINITELY stop getting gas at this same Shell station. I would actively look for a BP station and fill up immediately when able and also look into switching out your plugs.
Tech Info Resource
Injectors? Maybe you missed the fact there are 16 and 8 of them are DI. Swapping them out isn't called for at all.
10th Gear
Filled up at a new shell gas station, I poured in the fuel system cleaner from chevron. Still the same thing. I think might be my spark plugs? Do I go with OEM or with NGK. O’Reilly sells them for $30 a piece so $240 for a full set. Do I go with it?
10th Gear
Tech Info Resource
The DI injectors are $256.79 each from Rockauto. About $290 each from discount Lexus parts sources on the 'Net. So, a couple of grand just for the DI units, we haven't even touched the port injectors yet. You'd be way ahead to buy a can of BG44K and run that through your injectors first.
