Old 12-15-14, 11:42 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
The definitive IS-F illuminated door sills/scuff plate installation guide (w/photos)
Old 09-02-09, 03:15 PM
IceIridium
IceIridium's Avatar
Thumbs up The definitive IS-F illuminated door sills/scuff plate installation guide (w/photos)
Based on the requests I had on my pics thread, I decided to post specific details on the installation of the OEM Lexus lighted door sills.
There have been some confusion on ths installation of illuminated door sills on the Lexus IS (250/350/F). This is due to the different level of pre-wiring done on the car depending on the year, model, or trim of your IS.
Some cars are pre-wired for plug-and-play installation. Some have the plugs but are not grounded properly. Others don't have the plugs at all. On my IS-F, there was a plug on the passenger side that's not grounded properly, and no plug on the driver side at all. So depending on how your car is wired, just follow the relevant section of this guide and it should work on your car.
The pictures indicating "driver" and "passenger" side are based on my IS-F.
To remove sills and B-pillar cover, just pull them off. They're just held on by plastic clips.
Scenario: Has plug, but not grounded properly
Scenario: No plug
Careful handling the + and ground wires! especially since they're placed so close to each other in the plug.
This installation results in a simple ON/OFF function of the illumination. For cars that come with it from the factory, they fade in with the interior lights. If that is your goal, then I suggest grounding the wire onto the footwell light. I considered this option but decided on the door switch because both tapped wires are in the B-pillar, and also based on my experience with a demo IS250 with it the fade-in is so barely noticeable I saw no point in it.
Result:
Old 09-02-09, 03:24 PM
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
Thumbs up
My white sills have been installed for a few months... Just not wired!!!!
Now I have motivation for an excuse..
Old 09-02-09, 04:21 PM
passnu2
passnu2's Avatar
Thanks for sharing
Old 09-02-09, 05:30 PM
Evil Teo
Evil Teo's Avatar
now i have more detail thanks for the guide.
Old 09-02-09, 05:45 PM
IceIridium
IceIridium's Avatar
Just to mention that I used this thick white automotive wire for this install because I just happened to have it available at the moment. Thinner wire is fine and might be easier to work with. You may also choose to color-code the wires especially on the driver side in order to keep track of which is positive and ground.
Old 09-02-09, 06:52 PM
ISFer
ISFer's Avatar
Very nice, Ice....thanks for sharing.
C.
Old 09-02-09, 07:07 PM
FisforFast
F is for Fraud
FisforFast's Avatar
Helps a bit but I'm no electrician and wouldn't know how to tap into the goddamn wires or actually ground the thing.
Old 09-02-09, 07:19 PM
hahahaf
hahahaf's Avatar
excellent!!!!! u r the man
exactly the info im looking for
looks great
Old 09-02-09, 08:06 PM
fleadog99
fleadog99's Avatar
thanks, I think I will do this once I get my sills back from DFLORES. wink wink.
Old 09-02-09, 08:09 PM
CDNROCKIES
CDNROCKIES's Avatar
Very nice! Great info.
Old 09-02-09, 08:52 PM
s4play
s4play's Avatar
Verrrrry cool - this is something I seriously think Lexus should have done OEM!
Old 09-29-09, 05:09 PM
hahahaf
hahahaf's Avatar
if someone could clear this up for me that would be great
im about to install my sills this weekend
I would like to have them fade
ice suggests wiring them to the footwell light
is this the easiest location?
does anyone have experience with this?
what colour is the footwell light wire?
and where can it be found?
any help will be much appreciated
thanks
Old 09-29-09, 05:27 PM
T-Rex06
Ho Motorsports
T-Rex06's Avatar
Very nice write up. Now it's an excuse to buy the sills.
Terrance
Old 09-29-09, 06:46 PM
BigMikeISF
BigMikeISF's Avatar
Thanks for the writeup ice
Old 09-29-09, 09:15 PM
flipside909
Lexus Connoisseur
flipside909's Avatar
This is what CL is all about. Helping everyone out. Thank you Ice.
Quick Reply: The definitive IS-F illuminated door sills/scuff plate installation guide (w/photos)
