how to remove rear seat and rear deck
in case some of you are interested.
1. pop the seat cushion by pulling the seat upwards. the cushion should pop off easily. push the seatbelt buckles through the slots. the cushion now can be removed completely.
2. At the bottom end of the seatback, there are 4 black 12mm bolts that secure the seatback. one of each near the door and two of them are near the center console. DO NOT remove the seatbelt anchor bolts which are 14 mm. lift the seatback to free it from the three upper clips.
3. remove the C pillar cover. start from the lower edge and just using fingers to carefully pry them off. each piece should be held down by three blue plastic clips.
4. pop off the rear deck by lifting the front edge carefully. it's held down by three clips.
5. you now have access to the subwoofer or the brake light. the subwoofer is secured by four 10 mm bolts.
in the IS350 caymandive hit 12.8 with slicks bolt ons and removing seats ( think the fornt seat too. so on the F you should hit mid-low 12's easy by removing the seats, slicks, etc. all this in cold weather offcourse
possibly. you need to consider that cayman races at what is considered to be one of the fastest tracks in the nation.
I feel quite some resistance when pulling the seat upward, I would hate to break it
Could anyone confirm or tell me how to remove the bottom part of the rear seats.
- thank you in advance!
Is this correct? I am about to have my rear center tray wrapped in silver carbon. I was adviced to remove the seat to remove the tray........
Thanks for the write up! Maybe I can see whats going on with my woofer!
pics would be nice
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
Just did it.......popped right off.
scamsel (09-07-19)
