About the Unintended Acceleration...
Is there a computer reflash coming for this? A fix that is supposed to cause the brakes to override the gas pedal? Because if so, I DON'T WANT IT. And I'd hate to have to avoid the Lexus Service, but if they have agreed to do it, or are ordered to do it by NHTSA, they will reflash it if you just take it in for an oil change without asking you.
This exact thing happened to me before on a Cadillac Seville. Cadillac had changed the fuel mapping and it was not meeting the approved emission limits. I took it in for an oil change, they reflashed the PCM, and it lost about 30 horsepower right then, forever.
Toyota/Lexus are now completing what they are calling a "safety improvement campaign" that can consist of multiple steps. I know for the Camry and most likely ES 350 they are modifying/shortening gas pedals, modifying/removing sound deadening material from the floor pan and installing a brake override feature via ECM flash. Essentially what the override system does is cut engine power if both the brake and gas pedals are both applied at speeds above 10KM/H.
To the OP - no dealership at any time is legally allowed to complete any work on a vehicle whether it is warranty, recalls, or customer pay without telling you first. In fact this "safety improvement campaign" is not actually considered a recall (at least in Canada). It is something people with the affacted vehicles can have done if they wish primarily for added confidence and safety in their cars. It is not ordered by an ministry as a requirement to have done. I also highly doubt the IS-F would be affacted.
And that brake override should have been implemented since day 1 of DBW (drive-by-wire). No problem there.
I disagree. The brakes can overpower the acceleration anyway. With this nanny-minder, you lose a critical element of corner control in the twisties or road course, (the ability to preload) if you are a left foot braker.
Toyota Split Screen Braking Demo
Now I know they use a Corolla in the first demo but I'm sure the beefy brakes on the IS-F would do the same thing on that V8.
With the Camry’s throttle pinned while going 70 mph, the brakes easily overcame all 268 horsepower straining against them and stopped the car in 190 feet—that’s a foot shorter than the performance of a Ford Taurus without any gas-pedal problems and just 16 feet longer than with the Camry’s throttle closed. From 100 mph, the stopping-distance differential was 88 feet—noticeable to be sure, but the car still slowed enthusiastically enough to impart a feeling of confidence. We also tried one go-for-broke run at 120 mph, and, even then, the car quickly decelerated to about 10 mph before the brakes got excessively hot and the car refused to decelerate any further. So even in the most extreme case, it should be possible to get a car’s speed down to a point where a resulting accident should be a low-speed and relatively minor event.
http://www.caranddriver.com/features...tion-tech_dept
2003, acceleration, aceleration, brake, brakes, cadillac, engine, es300, gx470, lexus, loss, overpower, roar, sudden, unintended
