Anyone try a cheap throttle controller
Old 03-22-11, 07:40 PM
darbs242
darbs242's Avatar
Default Anyone try a cheap throttle controller
I was looking around and ran into this D1 spec throttle controller and wondering if anyone has tried them out... 120 bucks is pretty cheap if it works well.
Old 03-23-11, 11:16 AM
mikefate
mikefate's Avatar
Should work fine. The blitz isn't rocket science. It can easily be made for 1/10 the cost.
Old 03-23-11, 11:29 AM
DS2k
DS2k's Avatar
The only real "advantage" or selling point of Blitz is the PnP capability. If the one listed also has that option then I don't see why not! maybe you can try it out and let us know, please
Old 03-23-11, 11:38 AM
darbs242
darbs242's Avatar
They say is 100% plug & play
Old 03-23-11, 08:38 PM
Mitch08ISF
Mitch08ISF's Avatar
So does this affect the response difference that sport mode enables? The main reason I use sport mode is because in normal driving the throttle response sucks!
Old 03-23-11, 10:39 PM
JoshIS408
- - G T V I P - -
JoshIS408's Avatar
the only thing this does is allows you to set how sensitive your gas pedal is. I.e. Flooring it would the same as using this kit and pressing the gas pedal to ~ half throttle
Old 03-24-11, 10:56 PM
Dv8tion388
Dv8tion388's Avatar
Didnt the old Venom 400 module do the same thing sort of?
I would say a mod like this might be good if your trying not to break traction off a launch, no?
~Dv8
Old 03-25-11, 04:14 AM
ming15237
ming15237's Avatar
Are you sure about that? I was under the distinct impression that this item quickened the throttle response, not just simply exaggerated the throttle input.
Old 03-29-11, 07:02 AM
Juanca
Juanca's Avatar
This device is just a multiplier, it multiplies the input signal and as result you'll "feel" a quicker throttle response. Smash the gas pedal at once and you'll have the same result. There is no power added from this device.
HanaleiISF
07-14-17 01:02 PM
Meraki Autoworks
IS F (2008-2014)
23
03-27-15 03:29 AM
Meraki Autoworks
Performance
03-17-15 05:28 PM
lukeisf
IS F (2008-2014)
17
08-14-11 09:01 AM
UCLAJimmy
Performance
09-23-08 12:48 AM
Quick Reply: Anyone try a cheap throttle controller
