Need HELP! PPE Header install throwing a CEL
Before anyone gets me for not searching, I just want to say that I did, but the issue that others are stating is the same with the exception of one thing. So I guess this thread is different?
I got a call today from the Lexus Tech installing my PPE Headers and he mentioned the install was smooth but there was an issue with the o2 simulator/ wiring that comes with the headers. He followed the instructions, but the car throws a CEL for o2 sensor/ catalytic convertor with the wiring plugged into 12v power, but when he removes the 12v power from the supplied wires, the CEL clears and its good to go???
Could this be a faulty wiring issue on the supplied harness or maybe miswired by the installer?
OR
I need an aftermarket cat? Per the instructions, it mentions that I need an aftermarket cat.
OR
Cause im still running the stock exhaust system and that could be causing the CEL?
Any advice is greatly apprecitated, thanks in advance guys!
- Art
OR
OR
- Art
Have them hard wire the ground and power wires instead of using the blue taps and quick disconnects we include in the kit. An inadequate ground connection is the most common issue.
They can call us too if they want. 480-615-7900
OR
OR
- Art
OR
OR
- Art
I just had my PPE headers installed a couple of months ago and the install department said that the O2 instructions were incorrect. They had to trace the correct wires from the O2 sensors to the ECU and splice in the O2 sims. I didn't really listen to him because I was so excited but he said something to that effect that if I went exactly as the instructions, I'd have the wiring wrong. Have your tech trace the wires from the secondary O2 sensors so the correct wires are intercepted.
Sorry for all the concerns, Im sure every install is different. The issue the Lexus Tech came across was from the wiring, he did exactly as PPE mentioned in the thread and wired the 12+ and Neg direct and then he said after he cleared the codes the CEL didnt come back on. Please keep in mind this was yesturday around 5 ish so I didnt bother to pick up my car. I trusted the Tech to take the car for another day to test drive and work out all the bugs. So hopefully by later on today I will be able to get my car back. I also plan on making a video for those of us, like myself, that were wonderirng what the stock exhaust system would sound like with headers installed. <-- Im sure its raspy but hopefully its tolerable. I'll keep everyone updated and any other input is greatly appreciated, thanks guys!
Lou
I wouldn't be concerned - I didn't post my experience because nobody else seemed to have that issue. It could have also just been the service advisor blowing smoke. But I don't know why they would trace the secondary O2 wires to the pins unless what he was actually saying was correct.
The service manager simply said that what was written on the instructions didn't match what was in my car and would've resulted in the wrong wires being intercepted and a CEL. Maybe it was the wrong color or the wrong numbers? I don't know. I didn't ask specifically. Sorry. I highly doubt he remembers by now anyways.
Sorry that I can't help much - I've got my own problem I'm trying to figure out LOL (car clunking noises)
I had the same issues, the installation instructions were transversed so my shop made the switch the CEL went away, It's been almost a year and no problems.
No more CEL ! ! ! !
^ Not sure what others are mentioning with wiring changes that their shops made? but the Lexus Tech that installed my headers did exactly as PPE mentioned above and used a direct ground and a higher rated +12v fuse and was good to go. So far Im 35 miles into the PPE Header install and its all good with no CEL
I'm loving the new sound and increase in power! Now its time to go shopping for an exhaust!
