Feeler - GiroDisc 2 Pc Rotor
Old 01-12-13, 08:18 PM
flowrider
flowrider's Avatar
Received 1,900 Likes on 1,340 Posts
Default Feeler - GiroDisc 2 Pc Rotor
Our new Sponsor, http://speed-freaks.net, has asked me to get gauge interest in the GiroDisc 2 Pc Rotor See image below.
The preliminary feeling is that if they get a minimum of Five orders (sets), the cost would be somewhere in the neighborhood of $1,000.00 per axle (Front or Rear, or both). If there were Ten orders (again, an axle is a set) the price would be reduced to $900.00 per axle.
Anyone who places an order would need to post a deposit of $250.00 per axle.
The above is tentative, and if there were interest, Speed Freaks would provide full specifications.
Lou
Old 01-12-13, 08:57 PM
ilv1004s
ilv1004s's Avatar
so its 900 bucks per disc?
Old 01-12-13, 09:14 PM
flowrider
flowrider's Avatar
^^^^No, per axle, two discs, one for each side.
Lou
Old 01-13-13, 02:18 AM
Blacky
Blacky's Avatar
If you were in OZ I might be interested but not to be. Looking forward to seeing theses puppies.
Old 01-13-13, 08:12 AM
zapa
zapa's Avatar
Did they give you an idea of how much it would be to replace the one piece after it is worn out. I dont know what your really call it. The part the brake is applied to.
Old 01-13-13, 08:24 AM
kauaian
kauaian's Avatar
I believe it's called the disc.
I think I seen Adams had a very reasonable rebuild price for 2 piece rotors. I tried to post the info but their website seems to down...?
Old 01-13-13, 08:33 AM
zapa
zapa's Avatar
I know Figs has a set of 2 piece rotor on his website. I have no idea if they are any good though. The replacement "rings" as he calls them cost around 600
Old 01-13-13, 09:25 AM
kauaian
kauaian's Avatar
What is the advantage to two piece rotors?
Old 01-13-13, 09:36 AM
flowrider
flowrider's Avatar
^^^^It's my understanding that they are lighter and dissipate heat better. The 2-piece style itself is the main reason it is better with heat. Since the center of the rotor (hat) is not one piece with the "ring", heat transfer is not as great. So instead of it being one big chunk of steal that retains the heat built up over time, the outer ring deals with heat maintenance while the inner hat can just do it's job of holding everything together.
The hat is also made from aluminum. Again, lighter, plus aluminum has a better chance of dissipating heat.
And, IMHO, they also look sorta cool
Lou
Old 01-13-13, 09:50 AM
kauaian
kauaian's Avatar
Lou
Thanks Lou! That makes perfect sense and with that being said I take it the two piece rotor would be most beneficial to someone taking part in any activities that would generate a lot of brake heat. Not ideal for street use.
Old 01-13-13, 11:28 AM
flowrider
flowrider's Avatar
^^^^Why not for street use? Lighter unsprung weight is beneficial in the handling department
Lou
Old 01-13-13, 02:00 PM
ERDoc74
ERDoc74's Avatar
I would be interested in these... was planning on ordering from Figs in the next few weeks, but this could be slightly less in price... what about quality of these VS. the Racing Brake one's Figs is selling? I also wonder about replacement ring cost.....
Old 01-13-13, 03:25 PM
SpeedFreaksUSA
Former Sponsor
SpeedFreaksUSA's Avatar
Aside from the weight advantage, 2 piece rotors allow the rotor ring to expand / contract at a different rate than the hat. This reduces warping, distortion, and cracking when the rotor is subjected to heavy use and big swings in temperature.
Since the rotors run cooler and don't "cone" when they heat up you also get the added benefit of longer pad life and slightly more even pad wear.
-Matt
Old 01-13-13, 08:14 PM
96817isf
96817isf's Avatar
sounds sik as hell but it would be hard to compete with figs since they are selling theirs for half the price..im prolly goin with the figs one
Old 01-13-13, 08:51 PM
SpeedFreaksUSA
Former Sponsor
Where are you finding the racing brake 2 piece rotors for $500 per axle set? A quick look on their website shows them for $1250
-Matt
Quick Reply: Feeler - GiroDisc 2 Pc Rotor
