Lexon or Autocoture lip install
Old 01-30-13, 06:56 PM
TheHighLow
TheHighLow's Avatar
Default Lexon or Autocoture lip install
Do you guys know how either of these lips attach to the front bumper. I'm guessing that they use nuts and bolts, however, what about 3M tape? Do they require a lot of the tape?
It's such a PITA to remove it sometimes...
Old 01-30-13, 06:57 PM
1sWt2GS
1sWt2GS's Avatar
i dont know about these particular lips, but from a few lips install i ahve done myself, i use BOTH tape and nuts and bolts (washers both side)
better its a PITA to remove than having it fall off on the freeway and having to run over it, being dangerous, etc.
Old 01-30-13, 07:13 PM
bnizzle87
bnizzle87's Avatar
AutoCouture can be applied using 3M tape. It's already a tight fit as is on the chin of the bumper. I'm against drilling holes for any reason. I've had the 3M tape on my lip, and that that will simply not move.
Old 01-30-13, 07:14 PM
streetx
streetx's Avatar
the autocouture comes with screws but you will also need tape
Old 01-31-13, 03:35 AM
TeeLex
TeeLex's Avatar
The Lexon lip uses bolts and nuts, but I also applied some 3M tape, too.
Old 01-31-13, 03:04 PM
TheHighLow
TheHighLow's Avatar
is there drilling involved underneath the bumper for the lexon?
My concern with the 3m tape is that when/if I remove the lip it will pull the clear bra film right off with the film.....
Old 01-31-13, 03:16 PM
ISFpat
ISFpat's Avatar
There must be drilling.. Lexon is a chin lip, it'll never stay on with just tape
Old 01-31-13, 03:47 PM
CalitriSC
CalitriSC's Avatar
I have Lexon, uses 6 bolts that come with the lip. No tape is needed.
Old 01-31-13, 05:56 PM
TheHighLow
TheHighLow's Avatar
what part of the bottom bumper did you have to drill?
Old 01-31-13, 06:00 PM
CalitriSC
CalitriSC's Avatar
I dont remember having to drill any holes. It mounts to existing mounting locations.
Old 01-31-13, 07:28 PM
TheHighLow
TheHighLow's Avatar
thanx man!
Old 01-31-13, 11:38 PM
HyperMKIV
HyperMKIV's Avatar
the AC one didn't need tape for ours...
it's pretty snug and the bottom bolts hold it in place really well
Old 02-01-13, 04:33 PM
digger08
digger08's Avatar
Lip showing holes just to give you and idea
included nuts, bolts & washers
its not totally necessary, but most have used 3M tape to fill in the gap areas distanced from the bolts.
Yes you will need to drill holes in the bumper. When you test fit the lip, it will become very evident.
Digger08
Old 02-01-13, 07:10 PM
TheHighLow
TheHighLow's Avatar
Digger08
wait, so now I have 2 different opinions.
i'm confused, can someone else chime in on whether this lip uses pre-existing holes or are new holes drilled?
Old 02-02-13, 07:41 AM
digger08
digger08's Avatar
There is no pre-existing holes in your bumper?
Simply have a look at you bumper.
There is flimsy skid plate tabs at the very leading edge, but these in no way can be attached to your lip and handle 100mph speeds and they are way too far away from the predrilled holes in the lip. The only bolts that might work are the ends... on each side.
You will have to remove the bumper to install the lip and drill and reinforce with some sort of washer or banjo bolt system and then reinstall the bumper and lip together.
Digger08
Quick Reply: Lexon or Autocoture lip install
