Headers on 2011 ISF issues
Old 08-29-13, 06:22 PM
dave4262
dave4262's Avatar
Default Headers on 2011 ISF issues
I took my car to the dealer today to check out a rubbing sound when making left turns. It turns out my car have headers on it which is rubbing on the frame when making left turns. Does anyone out there have this issue and if so how do I fix?
I purchased the car 2 weeks ago.
Old 08-29-13, 06:27 PM
caymandive
11 Second Club
caymandive's Avatar
I would be ticked off buying the car with aftermarket headers especially ones that are problematic. Take it back to the dealership and have them removed. This should have been disclosed prior to buying.
Old 08-29-13, 06:37 PM
vbb
vbb's Avatar
Agreed. But it is entirely possible the dealership didn't even catch it. Also, if/when he gets to take them out, he may be a bit bummed by the difference in power. He's used to 40whp over stock.
Old 08-29-13, 06:46 PM
dave4262
dave4262's Avatar
Yes i am ticked off.. spent so much money and not even 2 weeks driving the car. I emailed the gm for the dealership hopefully they will replace. They are also replacing the steering shaft just my luck..
They did not disclosed any aftermarket parts on the car..
Old 08-29-13, 07:24 PM
ISFpat
ISFpat's Avatar
ill take it off the dealerships hands if they dont want it
Old 08-29-13, 08:14 PM
ROK
ROK's Avatar
OEM is best
Old 08-29-13, 09:06 PM
MK4Sup_isF
MK4Sup_isF's Avatar
Hahaha!!! Pat, I'm sure we can look around for stock exhaust manifolds to exchange with OP!!
Your subframe is either misaligned when they installed the headers or you got one of those Sikky that required some "massage" to get it away from the frame
Old 08-29-13, 10:36 PM
CUTigers
CUTigers's Avatar
Originally Posted by ROK
OEM is best
OEM is best?
Old 08-30-13, 03:29 AM
yjk1975
yjk1975's Avatar
I would be upset the dealer sold you a car without catts. That is illegal. So the leverage is completely on your side. Again you should take a pic of the headers. I would ask for OEM pieces to take home in case you need to put them on. But consider your self lucky. For exams I spent $3500 with install on my borla/ppe combo.
You will be disappointed to go from what you have back to oem. The sound I believe is a easy fix if you have the Sikky headers. You may even be close enough to go there and have it fixed. You have something touching the heat shield on your passenger side when turning. It may be as simple as bending the heatshield some. The steering may not have been put back correctly when the headers were installed.
2GRFE
05-06-17 07:47 AM
nicklausw
12
08-17-16 07:50 PM
SeanGTS
IS F (2008-2014)
02-26-14 08:47 PM
Stubagg
IS F (2008-2014)
02-10-11 04:56 PM
Quick Reply: Headers on 2011 ISF issues
