New brake pad option
After much debate and research. I wanted 4 things in a brake pad.
1. No Dust
2. Good Stopping Power
3. No Noise
4. Good Price. These were $79 for fronts and $29 for rears
some pads I researched had 1 or 2 of those qualities but not all 4.
I think I finally found what I was looking for. I say I "think" because i'm still in the break in period with these pads. but so far I'm happy for the price. Ive seen the wearever pads from Advanced. I actually wanted those, but they don't offer them in ceramic anymore. SO I went to autozone. Yes. That's right. I said autozone. I purchased their duralast gold pad.they are ceramic fronts and semi metallic rears. so far I'm extremely pleased with the pad. I didn't change the rotors. they feel very true. so I just ran my die grinder with a 3m scratching wheel over the rotor surfaces to remove the glazing and replaced the pads. Anyone that does a brake job on an F should also have some compressed air to blow away the brake dust. The holes in my rotors were chocked full of dust. Anyway here are the pads:
1. No Dust
3. No Noise
Heres the deal on the rears. I was told that the duralast gold are the same as the regular duralast pads so I bought the regular pads and I found this little note inside the box. So I got the duralast gold pads also
Oh. I saw everything else in the big brake thread but duralast. Must have missed it. anyway, these seem to be good pads so far.
I put a brand new set of those I got for free on my car went to the track and within 2 1/2 hours they were metal on metal..... Not a brake pad made to hold up to our cars. Factory brake pads will last mult track sessions
We have had a ton of success with the Project Mu NS400 being having all of the traits the OP mentioned with superior performance and feel to other low dusting pads. They come in at a higher price point than Duralast pads but there are benefits if the the driver prioritizes performance, quality and consistency. Also, if the driver takes the car to the track Project Mu also has more aggressive track compounds allowing you to just swap pads in and out and not worry about the different transfer layers not being compatible and causing issues.
-Matt M.
Lou
not precisely. I'm just making sure I don't have any 100mph stops for the first few hundred miles.
LOL! I know I edited my post to add 4 things. anyway. SO FAR SO GOOD. I wanted a ceramic pad for low dust. I wanted it to be quiet. I will probably NEVER track my car so no issues there. just a daily driver IF that. I drive my Jeep a lot too. My OEM pads were probably 40 to 50% remaining. So I thought what the heck if worse come to worst I can still use my OEM's. From what I have seen the Stop tech pads are around the same price and a lot of people are using those with less than favorable results. Some like em some hate em. AFTER I get a few hundred miles on these pads I will try to beat on em a little more and will post an update. I do believe more money will get you a better pad, but for under $100 I couldn't find any ceramics. the wearever pads were comparable to these with good reviews but they stopped making them in ceramic. The truth to these pads remains to be seen as im still "breaking them in"(going easy on them)
I'm just trying to be easy on the brakes for the first few hundred miles. Hence the bed-in process. basically moderate driving with normal stops and no fast or hard stops to overheat the brakes until an even film can develop on the rotors from the new pads.
Bedding-in new pads and rotors should be done carefully and slowly. Rapid heat build up in the brake system can lead to warped rotors and or glazed brake pads. Most brake pad compounds will take up to 300-400 miles to fully develop an even transfer film on the rotors. Following are the recommended bed-in procedures from each manufacturer:
AKEBONO
400 to 500 miles of moderate driving is recommended. Consumer should avoid heavy braking during this period.
ATE
BREMBO Gran Turismo
In a safe area, apply brakes moderately from 60mph to 30mph and then drive approximately 1/2 mile to allow the brakes to cool. Repeat this procedure approximately 30 times.
HAWK
After installing new pads make 6 to 10 stops from approximately 35 mph with moderate pressure. Make an additional two to three hard stops from approximately 40 to 45 mph. Do not allow the vehicle to come to a complete stop.When completed with this process, park the vehicle and allow the brakes to cool completely before driving on them again. Do not engage the parking brake until after this cooling process is compete.
AKEBONO
ATE
BREMBO Gran Turismo
HAWK
