Headlight Adjustment Success!
Old 12-31-06, 08:13 PM
jasonviper
jasonviper's Avatar
Hey Technique you think you can post some DIY photos of this?
Old 12-31-06, 08:36 PM
PearlTung
PearlTung's Avatar
Look in the owners manual. It shows where the adjustment **** locations are, if you can't locate them already.
Old 12-31-06, 08:54 PM
dat-is350
dat-is350's Avatar
Just wondering. What do you guys mean by teeth? Maybe I need to look at it to understand. =/ excuse my ignorance.
Old 01-01-07, 09:25 AM
linh811
linh811's Avatar
i didn't count the teeth, raised mine about 6 turns of the philips head screwdriver. looks a lot better now
Old 01-01-07, 09:28 AM
PearlTung
PearlTung's Avatar
6 turns x 4 teeth each turn of screwdriver = 24 teeth!
Old 01-01-07, 09:57 AM
linh811
linh811's Avatar
hmm, maybe I need another 6 turns
Old 01-01-07, 12:33 PM
Technique
Technique's Avatar
Originally Posted by dat-is350
I also noticed that the HID points low. I've always told myself to do it, but never got the time to. I just finally fixed my AFS light. I guess I will do this next time. Thanks for the info Technique.
What do you mean you "fixed your AFS light"?
Old 01-01-07, 12:39 PM
Technique
Technique's Avatar
Lightbulb Headlight Adjustment DIY Pics
OK, because I love you guys so much I went downstairs and took apart the engine covers and took pictures... Here we go...
Picture of the engine with all covers on:
Picture of the engine with all covers off:
Picture of the Driver's side headlight screw location:
Closeup of the Driver's side headlight screw:
Picture of the Passenger's side headlight screw location:
Closeup of the Passenger's side headlight screw:
Another closeup of the Passenger's side headlight screw with the arrow showing how the screwdriver should be inserted and the adjustment screw with a circle around it:
And of course, all of this is on my website as well...
Hope this helps!
justinmcc (11-14-20)
Old 01-01-07, 12:44 PM
racinghart
racinghart's Avatar
thanks man! builds up my confidence to go out there and do this right now!
Old 01-01-07, 12:45 PM
Cornellian
Cornellian's Avatar
Do you REALLY need to take ALL the covers off or can you just do it by taking off 2 or something?!?
flyfl1pguy
Registered User
flyfl1pguy's Avatar
good stuff Technique! I need to bookmark your page, so many useful things.
Old 01-01-07, 12:53 PM
BlitzIS350
BlitzIS350's Avatar
did the adjustment the other night. i took the liberty of marking the center point with a sharpie b4 i even made any adjustments so that way i know how many turn i make or where the adjustemnt dial is at. i didnt have to make too much of an adj tho, maybe about 1 full turn for the pass side and about a half on the drivers side.
Old 01-01-07, 12:56 PM
Technique
Technique's Avatar
No, I think you can just take the bottom cover off... But it might be SLIGHTLY easier to get at if you remove both of the sides ones too... I always just remove all the covers whenever I do any sort of engine work...
Remember, the passenger side cover only has one clip and one screw... and the driver's side has 1 screw and I think 3 or 4 clips, so they are much quicker to remove than the bottom one...
Old 01-01-07, 01:28 PM
jasonviper
jasonviper's Avatar
Good pics Technique. thanks again! so if your facing the windshield turn the screwdriver clockwise or counter clockwise??
Old 01-01-07, 01:53 PM
racinghart
racinghart's Avatar
its the same anyway you stand but turning the SCREWDRIVER counterclockwise makes the light go up. screwdriver clockwise = light aim goes down
Quick Reply: Headlight Adjustment Success!
