ECU Computer Reset Today at 5K Service
Old 04-08-07, 07:55 PM
Pwyll
Pwyll's Avatar
Default ECU Computer Reset Today at 5K Service
I brought my 350 in today for the 5K service and to have my winter tires removed and the summers put on. My "change oil soon" light came on last week and it was bugging me to see it every day, so I turned it off. When the oil change was done and they didn't see the light to reset, they reset the "ECU" computer, which also resets the adaptive transmission.
I never really knew how much the car learns your driving style. Because I only drive 1/2 mile each way to the train station (I commute into Manhattan every day), the car only learned that kind of shifting. Actually I was told that the car uses the driving characteristics for the first 1,000 miles to learn your driving style . I'm not sure if that is true, I thought it was continuously learning.
Anyway, lately I felt like the car had poor off the line acceleration.
When I picked the car up today after the reset, I couldn't believe how different it felt. It was like the rocket it was when I picked it up new.
Considering this, I am going to ask Lexus to reset the ECU at every oil change. If some of you out there are experiencing the same thing, I recommend it.
Old 04-08-07, 08:03 PM
joonsta
joonsta's Avatar
What if you have a lot of traffic in your area (Los Angeles) ?
Old 04-08-07, 09:01 PM
hapaboy
hapaboy's Avatar
this might be a dumb question, but how do you know they reset the ECU?
Old 04-08-07, 09:06 PM
acl15
acl15's Avatar
how do you reset the ecu anyways? disconnect the battery for 30mins?
Old 04-08-07, 09:32 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,020 Likes on 2,435 Posts
Just do this. It works.
Kamron777 (07-21-19)
Old 04-08-07, 09:36 PM
GOBUCS
GOBUCS's Avatar
You can reset the ECU yourself pretty easily. Lobuxracer has posted this a while back. To paraphrase somewhat: If you remove the EFI and ETCS fuses from the fuse box on the drivers side shock tower for more than one minute, the ECU will reset, without losing your radio or seat settings. Use a flat head screw driver to pop the fuse cover top off. { Have a pair of needle nose pliers handy when you are ready to pull out the 2 small fuses.} The top of the fuse box has a nice diagram of all the fuses on the underside of it. 3rd row from the left, The EFI fuse is a 25 amp fuse next to the 20amp fuse at the front of the box. ECTS fuse is the 10 amp toward the back of the box, third from the back. I have done this several times without a hitch, and now I have a mark on the fuse box to easily label the 2 fuses to take out for easy reference. One note though... each time I have done this, when you go to start the car, it will putter like twice and then not start. Try again and it is fine. Freaked me out the first time, thought I was screwed. Did the same exact thing when I reset the ECU months later.
I did notice a big change the first time I did this, but that was back when my car was new, and I was taking it a little easy during the {what??} break in period. Several months later, the second time I tried this, after driving robustly, I did not really notice a change at all.
SO, If you drive like a sissy, or are constantly stuck in traffic, you will notice a nice kick in the pants when you reset the ECU. If you drive like me, not so much.
Bxtaskforc (11-08-21)
Old 04-08-07, 09:37 PM
GOBUCS
GOBUCS's Avatar
Damn Lobuxracer, you beat me to it
On a side bar, I really enjoy your posts. Whenever I happen to see those molten headers, I'll always make a note to read what you have to say. You seem to know what you are talking about:}
Old 04-08-07, 09:47 PM
cancellino
cancellino's Avatar
Nice Post - Thanks for the information.
Old 04-09-07, 06:54 PM
cancellino
cancellino's Avatar
So I tried this today...figured why not - right? The car didnt start the first time, but second try was just like normal. Took it out and to my amazement it worked. It's like a new car again (only 2200 mles on It)
NOTE: There is a fuse puller in the block (white - to the right of the wire harness). Again Great Post - Thanks
Old 04-09-07, 07:22 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Originally Posted by GOBUCS
...One note though... each time I have done this, when you go to start the car, it will putter like twice and then not start. Try again and it is fine. Freaked me out the first time, thought I was screwed. Did the same exact thing when I reset the ECU months later...
I've put lightweight flywheels in 7 Scion tCs now in my garage. Part of the process is removing the battery completely from the car. I told every single owner to expect exactly this - sputter, no start, then fire on second attempt. It was true for all but one. One of them (for reasons I don't understand) fired right up on the first start cycle. But you are quite correct to warn about this. It scares a lot of people (and rightly so, I think.)
Old 04-09-07, 07:27 PM
caymandive
11 Second Club
caymandive's Avatar
I have a dumb question about resetting with the battery method. Does it make a difference if you disconnect the positive or the negative?
Old 04-09-07, 07:49 PM
Dj_AmtraX
Dj_AmtraX's Avatar
So, should I do some aggressive driving after this process for better performance???
Old 04-09-07, 07:58 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
No, but usually the negative lead is easier to remove. Not sure about the ISx50 though. I never remove the battery unless I absolutely have to. I hate losing all the presets. I've even seen a gizmo you can plug into the cigarette lighter with a 9v battery to hold all the presets when you disconnect the battery. Of course it defeats the whole ECM reset thing. I just do the fuses...
Old 04-09-07, 08:04 PM
Batmobile
Batmobile's Avatar
yeah that's the same question i had... if the car takes roughly 1000 miles to "learn" how you drive should i drive like an a-hole everyday?
Old 04-09-07, 08:07 PM
Pwyll
Pwyll's Avatar
I'm glad to see this has been successful for some of you guys.
Question. I understand that if you disconnect the negative to the battery, the radion presets will be wiped. What about other presets such as seats, etc. BUT MORE IMPORTANTLY, THE NAVIGATION SETTINGS??
Anybody know?
Thanks
Quick Reply: ECU Computer Reset Today at 5K Service
