auto trans stumbling???
For a few weeks now, I've noticed a "stumbling" or "jerk" from the transmission when coming to a stop. Like the car jerks forward slightly as the engine is winding down on the rpm's. It only happens when the car has been sitting all night and is cold. And only from about 3-2 mph right before coming to a stop. I've even noticed it once when accelerating from a stop (1 to 2 mph). Lifted foot of brake and it jerked slightly. (Maybe it's not even the trans?)
Is this a known problem? Can't say that I've heard of such a thing or seen anything come up in the search.
Thanks
Thanks
^^^I dont think their is a problem with the vehicle. I have experienced this in my Audi A4 and now my brand new Lexus is250. I honestly think it has to do with the ecu and or tiptronic transmission.
I think the ecu is the primary cause. It is trying to anticipate what you are doing. It doesnt know if you want to be in 1st gear or 2nd gear. It also might be due to the fact it is a tiptronic transmission. I have driven many cars without tiptronic but with an ecu learning system and it doesnt have this problem.
I know exactly what you are talking about though...Its especially annoying in stop and go traffic. It is very jerky. Im interested in seeing a solution too...if one exists
Super Moderator
For heavy stop-and-go traffic, put the transmission in snow mode. It gets rid of all that hunting and shifting; much easier to drive the car smoothly.
I am kind of surprised such a characteristic fell through the cracks in programming the car. Otherwise, the engine idle is so smooth you can hardly tell the motor is running.
Thanks
Thanks
This often happens with my mother's 2003 Hyandai Santa Fe AWD. I even changed the tranny fluid with type "H" and added Slick 50 high mileage treatment. Although it shifts smooth, I still experience that same phenomenon. Definitely an ECU for the trans control.
I have this problem too in my 250, but it only occurs when I put the sequential mode in the 1st gear when the engine is cold and when I release the brake. This stumbling soesn't occur in "D" gear position and the same conditions. The stumbling disapears after 2 or 3 minutes.
Is this a real problem?
