Went for an Alignment... but have problems...
Tech Info Resource
I lowered it in Feb and i just aligned it yesterday... so 5 months.... You should be fine if your doing it this soon, although this may happen to you in the near future as the springs set.
just fyi for me, the dealer should still do my alignment under warranty, right?? i just got my fsport springs today, gonna have a buddy of mine install them then get them re-aligned.
Why would the alignment be covered under warranty? You're asking them to perform a service. Warranty is only for defect issues; you modifying your car doesn't count.
FWIW, my dealer charged ~$80 for an alignment.
The correct thing to do is reset the bushings (procedure described in the FSM) when the springs are installed. Then it can be aligned immediately.
Tech Info Resource
Everything related to toe is out of specs. Their numbers for minimum and maximum are wrong, and where they set them for the rear will lead to inside edge wear for sure.
For the front tires - assuming they're 225/40/18 - each millimeter of toe is roughly 0.1798 degrees. Spec is 1mm +/- 2mm. So total front toe should be -0.1798 to +0.5395 degrees, not -0.15 to 0.40 degrees as listed on the sheet. The minus number is toe out. Somebody didn't use the right tire size when calculating those angles.
For the rear tires - assuming they're 255/40/18 - each millimeter of toe is roughly 0.1733 degrees. Minimum spec is 1mm, maximum is 5mm, both are toe in. So Lexus spec is 3mm +/- 2mm or 0.5199 degrees +/- 0.3466 degrees (0.1733 to 0.8665 degrees is the acceptable range). Your setting, IME, should be at minimum spec for longest tire life, so your total toe should be 0.1733 degrees.
At 0.9 degrees total toe in the rear (where they set yours), you're at 5.1935mm which is WAY too toed in and IME will kill the inside edges of your tires very quickly. This is the setting you'd use for a track car where turn in is the primary concern and tire wear is a secondary consideration, not a street car where tire life is the greatest concern.
Springs don't settle. The bushings deteriorate if the installer doesn't reset them when they change the suspension, and some people mistake this for settling.
Tech Info Resource
Draw a trapezoid with the ends the same length as the diameter of the wheels and solve the triangle on each end. You know two sides, toe value and wheel diameter. Divide toe by wheel diameter and take the arc sine of that number to get degrees. You can calculate this for each wheel or total toe, but the numbers I provided are accurate for the front and rear wheels on the IS350 with 18" wheels and OEM size tires. If the tire size changes, the angles change. Lexus does NOT specify angles, they specific millimeters, so most alignment shops using angles provided by their machines are going to get this wrong unless they calculate the correct angles based on the factory spec and the tires mounted on the car. Now I know why I never had a problem with the alignments I got in Sacramento - the tech used a scribe to make a tiny slice around the tire for measurement, then used a bar with sliders on it to measure front and rear by distance, not by angle. The machines aren't smart enough to compensate for this and they're using a database with fixed angles, not actual measured toe settings.
See diagram for how I calculated it:
