TPMS compatibility
Old 12-06-09, 07:51 PM
Stevoe88
Stevoe88's Avatar
Default TPMS compatibility
Hey sorry for the noob question, but I couldn't find any answers looking through the forums. Will the 2006-2008 TPMS work with my 2009 IS250? Thanks in advance
Old 12-07-09, 07:34 AM
mikes rx
I use "..." ....... a lot
mikes rx's Avatar
Search is your friend.....
But yes, it should. My pre 4/06 TPMS sensors were able to be programmed to my 2010 IS
Old 12-07-09, 10:46 AM
javyLSU
2IS OG
javyLSU's Avatar
There are actually only two types of Lexus TPMS for this car - those for build dates of pre-April 2006 and those for post-April 2006 builds. I successfully had the post-April 2006 sensors programmed into my pre-April 2006 IS, and mikes rx posted above, the same is true in the opposite case - so pre- or post April 2006, it doesn't matter. They'll work.
Javier
Old 12-07-09, 01:25 PM
Stevoe88
Stevoe88's Avatar
So for instance, I get 2006 wheels with TPMS in them. Do I have to do any special programing to have the computer read the TPMS?
Old 12-07-09, 05:56 PM
mikes rx
mikes rx's Avatar
all tpms sensors will require programming into the car via Toyota/Lexus hardware....unless the aftermarket (ie-tire dealers) have caught on and is able to program them with special equipment.
Old 12-07-09, 10:34 PM
Pnuge88
Pnuge88's Avatar
you can sometimes get them programmed for free through your dealership. they use a computer called a techstream to enter the codes that are on each tpms
Old 12-08-09, 04:25 PM
Stevoe88
Stevoe88's Avatar
aw damn lol so i probably have to get it programed to my car then huh. Would it require taking off the tires or can they just do it via obd2/something else? I doubt they would do it for free if they have to dismount/mount tires lol.
Old 12-08-09, 04:34 PM
mikes rx
mikes rx's Avatar
Apparently the technology is there to be able to read the codes off the sensors using a special handheld scanner----thus not requiring dismounting the tires. I think what they do is lower the air pressure in the tires so that the scanner can show the change and the sensor causing the change.
But, I don't know if that's only on the post-4/06 sensors or not.
pebbleh
RX - 4th Gen (2016-2022)
07-23-17 05:54 PM
jdlsantos
Wheels and Tires Classifieds
11-30-12 04:55 AM
BinaryJay
11-24-09 07:39 AM
AK-47
04-13-09 09:12 PM
Benji668
10-12-07 07:56 PM
Quick Reply: TPMS compatibility
