Need HELP!!! ASAP (LED Tail Light Problem)
So i just received my LED tail lights earlier today and when i installed it (had a hard time, tap the wire and everything), all of the warning signs on my cluster gauge, like my brakes, low gas warning, skid mark, and such...How do i turn off all these warning lights?? I tried to reset the car battery but still, all warning lights came on. Please Help...
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
^^^ No it was not. had to mess witht the wire but lights are workin fine its just all these warnin lights came on and i cant turn it off. It says check VSC, wdh is that???
Sounds like a power to ground problem! *Check your wiring! Start all over, and check with a dmm (volt meter) the power's for each function-
Is that led setup a chepo type? (manufacture defect)
oh really, damn, i guess i might have to do the same and return this P.O.S lolz j/k it does look pretty nice though. what if i take it to Lexus dealership, you think they can turn it off? watch they charge me $300 for that
You need a resistor to cancel out all the warning signal.
I got the same problem last time, end up paying $40
to have someone install the resistor. If you can find
the right resistor, the installation is very easy.
