TPMS (ideas) ??
Old 02-03-10, 02:16 PM
Edz71
Edz71's Avatar
Default TPMS (ideas) ??
Hi all,.....
Has anybody taken the tire sensors off the factory wheels and put in them in the spare tire. I was told it’s a option for those of us with aftermarket wheels to fool the computer and avoid the TPMS alarm.
Thanks,....... Edz
Old 02-03-10, 02:25 PM
NSGxLEX
NSGxLEX's Avatar
i have a friend that did this. dont know the details but i know it works
Old 02-03-10, 03:23 PM
tnogi
tnogi's Avatar
This sounds crazy but would love for this to work
and if someone could share details? thnx
buMp this thread...
toHn
Old 02-03-10, 04:32 PM
Edz71
Edz71's Avatar
buMp this thread...
toHn
From what I have been told you take the 4 sensors and tape them to the inside of the spare wheel inflate to 35 psi and thats it. I can't see why it won't work ?? The TPMS system only warns you of low preasure not which tire is low so if all the sensors are under preasure it should work.
Old 02-03-10, 05:41 PM
edgeucated
edgeucated's Avatar
i know other members have done this. it works
Old 02-03-10, 06:09 PM
Damaster32
Damaster32's Avatar
i did it, works like a charm
Old 02-03-10, 06:27 PM
tastfulmod
tastfulmod's Avatar
Haha never thought of this. Glad someone mentioned it. Now I am going to try it. Lol
Old 02-03-10, 08:01 PM
Kurtz
Kurtz's Avatar
This works so long as:
You don't care if the system doesn't inform you when your tires are low (which the OP clearly doesn't)
AND
You don't ever plan to use the spare (which the OP might)
Old 02-04-10, 04:03 AM
Edz71
Edz71's Avatar
Thank you Sir,........... and everyone for the input !!!
Old 02-04-10, 04:36 AM
IXI187IXI
IXI187IXI's Avatar
or you can build a little home made canister at home depot for like 15 bucks. make it air tight and put the sensors in there and inflate. problem solved.
on another note, ive had my oem wheels off my 3GS for a few weeks and i never once got a low tire pressure light on.
Old 02-04-10, 05:56 AM
Kurtz
Kurtz's Avatar
Do you park anywhere near the wheels? that's good enough.
Old 02-04-10, 09:10 AM
combfilter
combfilter's Avatar
there is a DIY on the pipe bomb canister in the faq's at the top of the 2gen is forums.
Old 02-04-10, 09:17 AM
IXI187IXI
IXI187IXI's Avatar
nope.......
Old 02-04-10, 10:30 AM
mdsbrain
mdsbrain's Avatar
This is from the FAQ section of a nice write up:
https://www.clublexus.com/forums/is-...pipe-bomb.html
Old 02-04-10, 10:31 AM
ennjay
ennjay's Avatar
personally i would get rims that are TPMS compatible, but I'm OCD like that.
Quick Reply: TPMS (ideas) ??
