Lexus IS250 4GR-FSE Engine Carbon Build-up (merged threads)
Old 07-04-10, 08:45 PM
  #256
quick123
quick123's Avatar
Originally Posted by Stock4AG
Why brake booster? You can pull one of the tubes off the intake manifold and they will have a vacuum thats where you can inject stuff.
The brake booster works off of vacuum pressure from the intake manifold...easy to see and you know it is a vacuum line...
The booster is on the driver side of the firewall...you can't miss it, it is round...
Old 07-04-10, 09:06 PM
  #257
SC3coupe
SC3coupe's Avatar
The brake booster seems kind of far, find the PCV line would be better.
Old 07-06-10, 11:44 PM
  #258
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,018 Likes on 2,434 Posts
Originally Posted by Dabigman
Lobux -
Can you comment on the impact (or lack thereof) on the use 10% Ethanol gas and this problem on the 2GR/4GR engines? I know that the Ethanol blend sucks and takes 5MPG on my engine but I don't know how it affects carbon build-up.
TIA.
Ethanol content won't make any appreciable difference if the cause is what I suspect.
Ethanol has a low specific heat, so it will always have a lower mpg number. It's not related to deposits in any way.
Old 07-07-10, 01:40 AM
  #259
IS25Heaven
IS25Heaven's Avatar
This actually happened to me, came to a stop the rpms dropped to 400rpm. And the entire car shook. Time to hit up the dealership
Old 07-07-10, 06:46 AM
  #260
SC3coupe
SC3coupe's Avatar
What can we do to prevent it?
Italian tune up?
Others car owners like mini are claiming bg44k helped
Old 07-07-10, 06:56 AM
  #261
quick123
quick123's Avatar
Italian tune up?
BG makes an excellent product...any top engine cleaner will help breakdown the carbon build-up, and should be used about every year (everyone has their own opinion on this)...some people on this forum have suggested going WOT every once in a while and it seems to help
Old 07-07-10, 08:11 AM
  #262
SC3coupe
SC3coupe's Avatar
I am getting some bg44k and use it every 10k and see..
Old 07-07-10, 10:28 AM
  #263
cchase231
cchase231's Avatar
I was just looking at the BG product website and according to them the best way to do it is to run the fuel injection cleaner first to "pre-soak" build up and that makes the 44k more effective. It also says after that to run their gas additive with every tank after the 44k is used? Seems a bit pricey and unrealistic. Then they have the CF5 which they say to use every 5k as a preventative measure. I did read some posts here where people had the top engine cleaning done and it didn't fix the issue at hand, the only explanations I can think of are the cleaning wasn't thorough enough or the build up in the top engine is not the cause of the problem, I would be interested to see an explanation from someone who is more mechanically inclined than myself. Is it the consensus that this is an inherent problem with the direct injection and it can't be "fixed" just dealt with?
Old 07-07-10, 10:38 AM
  #264
SC3coupe
SC3coupe's Avatar
I guess the BG44k is for the injectors which COULD also suffer from carbon buildup and contribute to crappy idle.
Found this:
"the 44K is about twice as strong as the CF5. Both are excellent products. Use the 44K for the initial cleaning then use the CF5 every 5K thereafter"
The CF5 I think I could use. It couldn't hurt anything. I am not expecting a miracle.
Technically the additives will not hit the valves much, I am not sure when the injectors fires.
I am gong to order both. My car has 12k mileage so far I think it runs like new still.
Old 07-07-10, 10:55 AM
  #265
SC3coupe
SC3coupe's Avatar
check out this cleaning done for Audi
http://vimeo.com/3989681
Old 07-07-10, 10:58 AM
  #266
cchase231
cchase231's Avatar
So you don't have any problems so far? It will be interesting to see how it goes as you put more miles on it. But not 4gr drivers are experiencing these problems so I guess it is kind of hard to quantify the results.
Old 07-07-10, 11:04 AM
  #267
SC3coupe
SC3coupe's Avatar
No I don't notice any symptoms, I didn't know about this until I come here and read stuff like this. Then again a 40k mileage vs my 12k could be a big difference.
I drive like very non aggressively also which is supposed to be bad.
Old 07-07-10, 11:27 AM
  #268
SC3coupe
SC3coupe's Avatar
Here is some info I got from a seller on Ebay
"44k is 2 to 3 times as strong as cf5. cf5 can be use every time you fill up. 44k should only be used every 5 thousand miles. "
So I guess do the 44k only every 5k, to me the cost isn't bad. Less than $20 a pop
Old 07-07-10, 11:57 AM
  #269
ajfinoak
ajfinoak's Avatar
As I understand this, the 350 also has direct injection but the engine was designed differently so that they are not experiencing the pronounced carbon build up (of course, they have the other recall issue). I also understand that carbon build up can be a problem with DI engines. While I am not an engineer having this problem begin at very low mileage IS unacceptable and likely a poor design issue. Since the top engine cleaning appears to be at best a temporary solution I don't feel it should be the responsibility of the 250 owners to try to figure out what additive or process can help this. I would suggest that 250 owners with this problem continue to contact Lexus Corporate for them to figure out what to do (i.e. if it will be recurring, extend warranty)
Old 07-07-10, 02:03 PM
  #270
SC3coupe
SC3coupe's Avatar
The IS350 has port injection too, and maybe the problem is less because of that.
If you think speed of build up is unacceptable, there are other more expensive european cars where this occurs more severely in a shorter amount of time.
It will be nice if perhaps we complain enough Lexus will give us free head cleaning for the lifetime of ownership but somehow I don't think it will happen. I don't think it's a bad suggestion but before that happens I would like to do preventative maintenence on my car.
The BG induction service in the video looks easy enough to do (and fairly non intrusive), it cost maybe $120 at some dealers. I am concerned what might get dislodged into the first catalytic converter. But then the exhaust temperature of 800F actual driving it may eventually get burnt up.
Quick Reply: Lexus IS250 4GR-FSE Engine Carbon Build-up (merged threads)
