NGK spark plugs now available
#38
i keep leaving them at home lol i keep forgetting to bring them to work so i can install em right when i get off. I can get the OEM densos for $6-7 a piece (use to work at Lexus).. I work at Honda now and they are a NGK distributor. I tried getting a discount on the NGK's but I guess it's too new the parts department couldn't even order it/find it.
#41
sorryy guys I couldn't do the DIY. I left the camera at home. boo me yeah.. lol maybe it's in my head but the car runs smoother? haha idk!
The tools you will need are :
5mm Allen key
10mm socket
12mm socket
Extension!
spark plug socket or 16mm
I used the 16mm to tighten the spark plugs back up because the spark plug socket keeps getting stuck cause it's got that kung fu grip. I used the spark plug socket to take the old spark plugs OFF
The RIGHT SIDE
Taking off the intake manifold was a PITA cause of the 12mm bolt behind the manifold you gotta take off. other then that it's plain simple guys. once you remove your engine covers. there should be like... 4 5mm allen key bolts and 3 10mm nuts to take off. Also 4 10mm bolts where the throttle is. unplug some connectors.. remove a hose or 2 from the clamps. and have fun. Don't forget you gotta buy 3 pairs of gaskets for the intake manifold. Oh and you need a 12mm wrench or whatever works for you to disconnect the fuel line.
THE LEFT SIDE
Just remove your intake.
sorry that I have no Pictures... IF you guys just look at your engine bay it's pretty common sense.... and if you do look at it you'll know what I'm talking about in my post.
5mm Allen key
10mm socket
12mm socket
Extension!
The RIGHT SIDE
THE LEFT SIDE
#44
haha let me ride on it a couple days. I don't think changing spark plugs makes a difference..
IMO i say just stick with OEM cause it's cheaper.
my spark plugs weren't that bad either.
so IMO for those who debate on changing them at 60k or 100k. You can ride on it until 100k no problem. The oem denso plugs are quality too.
i will take pics of my old plugs whenever i feel like it :P
#45
Guys, talk to any ASE tech and they will tell you to use the same plugs that came with the car from the factory. Engines are designed with a certain plug, why would you change that? When the engineers built this awesome motor, they did it with Denso plugs. Running a different plug is not what the motor is designed for.
NGK is for Honda, Bosche are for German cars, Mastercraft for Ford, AC Delco for GM, and.....Denso are for Toyota/Lexus. You can actually make the engine run worse with different plugs, and sometimes the plugs can run hotter and even sieze inside the heads.
Be careful with part selections, and sometimes factory is the best even though it is boring...
