Will those Wheels Fit an IS250 AWD - Part Uno
Old 08-20-10, 10:31 AM
netsrac
netsrac's Avatar
Default Will those Wheels Fit an IS250 AWD - Part Uno
OK I have been going through the Will Those Wheels Fit? Start Here...
From what I have read, IS350 and IS250 and IS250 AWD do not share the same specs when it comes to wheels & tires.
I find the thread confusing, because not everyone says what model they have. (not to mention the 95+ pages)
I thought maybe I could start a thread just for people who have a IS250 AWD
Maybe they could state what after market wheel/tire sizes / offsets they have
With the permission of the mods, I would make a list of all that works by editing this post with responses.
Tire Size Calcualtor
IS250 AWD 2006-2010
OEM
F & R 17x8 45mm offset 5x144 - Tire 225/45/17
None Staggered Set-up's
F - 19x9__40mm offset__tire 235/35/19
R - 19x9__34mm offset__tire 235/35/19
Thanks to Iaobo979 Staggered Set-Up Thread started by mdgrwl Good read, below are some set-ups from that thread ordered by size.
F - 18x8____not listed____tire 225/40/18 "OEM wheels from IS350"
R - 18x8.5__not listed____tire 255/35/18
F - 18x8____35mm offset__tire 235/40/18
R - 18x10___38mm offset__tire 275/35/18
F - 19x8.5__35mm offset__tire 235/35/19
R - 19x9.5__39mm offset__tire 275/30/19
R - 19x9.5__36mm offset__tire 265/30/19
F - 19x8.5__36mm offset__tire 235/35/19
R - 19x9.5__37mm offset__tire 265/30/19
F - 19x8.5__40mm offset__tire 235/35/19
R - 19x10___45mm offset__tire 265/30/19
F - 19x8.5__40mm offset___tire 235/35/19
R - 19x10___38mm offset___tire 275/30/19
F - 19x9_____not listed____tire 235/35/19
R - 19x9.5___not listed____tire 265/30/19
F - 19x9____22mm offset___tire 225/35/19
R - 19x10___22mm offset___tire 235/35/19
F - 19x9____25mm offset___tire 225/40/19
R - 19x10___35mm offset___tire 255/35/19
F - 20x8.5___30mm offset____tire 245/30/20
R - 20x10____38mm offset____tire 285/25/20
jcgeorge (08-31-20)
Old 08-20-10, 11:10 AM
laobo979
laobo979's Avatar
Stagger will work as long as your stay within the stock diameter search stagger awd and it will pop up. And the 250awd, rwd & 350 wheel will all have the same bolt pattern.
https://www.clublexus.com/forums/is-...er-thread.html
Old 08-20-10, 12:51 PM
mikez
mikez's Avatar
You forgot mine:
18x8 +35 - 235/40/18
18x10 +38 - 275/35/18
Old 08-20-10, 01:02 PM
netsrac
netsrac's Avatar
Originally Posted by mikez
You forgot mine:
Noted and added
Thanks
Old 08-21-10, 10:13 AM
Tajai7
Tajai7's Avatar
Would running 19x8.5" rims all around look odd w/o a lowering springs or coilovers? I just want to get the stock 17s off my AWD and would like to put 19s on -- assuming it doesn't look dumb. Thoughts? Any pics of an AWD w/ 19s that is not dropped? Thanks.
Looking at putting on aftermarket tires: 245/35-19 (tire height: 25.75")
Stock tire specs: 245/45-17 (tire height: 25.68")
Old 08-21-10, 11:54 AM
pchan0
pchan0's Avatar
I didn't do staggered 19s for my AWD. Specs, 19x9 +40 F, 19x9 +34 R. 235/35/19 Hankook V12. My next set will probably be staggered.
Old 08-21-10, 01:28 PM
netsrac
netsrac's Avatar
Good question, would be nice to see, as I have not lowered mine yet, and would probably only lower after new wheels.
Thanks, now did you need to use different sized offsets for the rear?
Old 08-22-10, 09:53 AM
javyLSU
2IS OG
javyLSU's Avatar
I've linked this thread in the original post of the "Will those wheels fit" thread to help AWD owners find this information. Good luck guys!
Javier
Old 08-22-10, 01:56 PM
J250
J250's Avatar
good thread, this will definitely help out AWD owners. For 19x8.5, 19x10 you can run 235/35/19 and 275/30/19 to get EXACT overall diameter. That's my setup with +42F and +38R
Old 08-22-10, 07:10 PM
netsrac
netsrac's Avatar
Thanks added
Also can tell me why you are running a smaller offset on your rear, when everyone else is running smaller on their fronts.
Thanks
Old 08-22-10, 07:11 PM
netsrac
netsrac's Avatar
Javier
Thanks Javier
Old 08-23-10, 01:01 AM
J250
J250's Avatar
Originally Posted by netsrac
Thanks added
Thanks
My rear offset is actually more aggressive than my front offset. Closer to 0 the more aggressive it is. My front's offset is pretty weak because i'm trying to avoid any rubbing.
Old 08-23-10, 07:47 AM
PaPaHoFF
PaPaHoFF's Avatar
I am running the following:
Rims
Cordon Alloys CR-10 Matte Silver w/ matte black accents and chrome lip.
Tires
Vredestein Ultrac Sessanta
Front
20x8.5x30 Rim 245/30/20 Tire
Back
20x10x38 Rim 285/25/20 Tire
Ive ran the same tires on my previous staggered setup with no problems for about 2 years already.
First AWD on AIR!!!!!
Pics
Old 08-23-10, 08:47 AM
netsrac
netsrac's Avatar
Rims
Tires
Front
Back
Pics
Thanks, had your set-up down but was missing the offset.
Love your ride
BTW can you explain the hood and how you got it?
Old 08-23-10, 10:48 AM
mikez
mikez's Avatar
He bought it from me, cost him his *****
Quick Reply: Will those Wheels Fit an IS250 AWD - Part Uno
