First mod: LED puddle lights + LED interior
today i've done the first mod ever to ANY car!
bought the 2W flanks and 2W festoons from vleds
got the rest of the LEDs from ebay to save up on money
![](http://i11.photobucket.com/albums/a162/SilentWish331/IMG_2930_resize.jpg)
ebay 1W flank vs vled 2W flank
(i wouldn't recommend this 1W flank from warden_jp2008 the input is too thick and spread the connectors of the car too wide apart! i put this flank into my driver's side vanity lights and puddle lights, and after pulling them out and putting other bulbs back in, the connectors have become very loose!)
![](http://i11.photobucket.com/albums/a162/SilentWish331/IMG_2950_resize.jpg)
Original puddle bulb
![](http://i11.photobucket.com/albums/a162/SilentWish331/IMG_2951_resize.jpg)
waden_jp2008 flank LED
![](http://i11.photobucket.com/albums/a162/SilentWish331/IMG_2953_resize.jpg)
vleds 2W flank LED
the flank LEDs from vleds are noticeably brighter and do not stretch the connectors as their inputs are thinner, i'm another person on the long list who would recommend these for puddle lights if you're looking for brightness![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
![](http://i11.photobucket.com/albums/a162/SilentWish331/IMG_2924_resize.jpg)
ebay wide angle LED vs ebay 1W LED
(both of these LEDs are again from warden_jp2008. the wide angle ones really provide a wider angle than the normal 1W LED, so the seller wasn't bsing! their brightness are about the same though)
![](http://i11.photobucket.com/albums/a162/SilentWish331/IMG_2934_resize.jpg)
original dome
![](http://i11.photobucket.com/albums/a162/SilentWish331/IMG_2946a_resize.jpg)
LED dome (wide angle LED on the two sides + 1W LED in the middle)
if you're ever interested in the wide angle LEDs, they do not fit through the hole if you install using the method where you pull down the entire top console, you must twist them in by removing the light cover
for me, both installation methods were easy, although removing the light cover literally took 2 seconds for me, whereas unscrewing the screws above the sunglasses holder and pulling the console down would obviously take longer
![](http://i11.photobucket.com/albums/a162/SilentWish331/3_resize.jpg)
Original rear dome
![](http://i11.photobucket.com/albums/a162/SilentWish331/3a_resize.jpg)
vleds 2W Festoon LED rear dome
my conclusion for vleds vs ebay LEDs are:
if your priority is brightness, then i believe vleds currently have the brightest 2W LEDs. As for the interior, if you don't mind about brightness but just want the white lighting, ebay LEDs are fine are aren't that much dimmer than the vleds. however, i can't comment on durability as i've just installed them today. I'll have to see if the vleds ones have a longer life than the ebay ones.
![](http://i11.photobucket.com/albums/a162/SilentWish331/IMG_2964_resize.jpg)
![](http://i11.photobucket.com/albums/a162/SilentWish331/IMG_2970_resize.jpg)
![](http://i11.photobucket.com/albums/a162/SilentWish331/IMG_2980_resize.jpg)
![](http://i11.photobucket.com/albums/a162/SilentWish331/IMG_2987_resize.jpg)
vleds 2W flank LED
original dome
Original rear dome
![](http://i11.photobucket.com/albums/a162/SilentWish331/IMG_2989_resize.jpg)
thank you so much!
lol that's how i decided to go with the 2W flanks and festoons because i went them to be as bright as can be~ the rest weren't my priority
they're made for awd as it has the indent on the driver's side for the extra room it takes up for the awd
and perhaps cause i'm in canada so we have special winter mats for the snow?
nevertheless.. i think the mats look very good!
you can't really see cause the seat is in the way.. but at the very bottom of the mat is actually says IS in white font, really nice!
