Sun visor Lights Not Working, Help
I recently found out both sides of my visor lights are not working when I slide the slider for the mirror. I assume it's the fuse that's blown.
Can anyone help as I know the fuse is under my steering wheel but I don't know which one to check. If anyone can share some info or can provide pics to show me how to rectify the problem, it'll be much appreicated, thanks.
On the driver side underneath your instrument panel/steering wheel:
![Name: Untitled.jpg
Size: 12.4 KB](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/434876d1501367096-sun-visor-lights-not-working-help-untitled.jpg)
Check fuse #18 in the above diagram. Should be a 10amp low profile fuse.
There should be a diagram on the lid of the fusebox too.
I've been having the same problem. My light actually flickers and it looks like I have a rave party in my car at night when I use them. I went to the dealer and asked them if they could fix it and they said that there is a switch inside of the visor that you have to enable...by doing that you have to mess around with the slider until the light turns on. I tried doing that and it didn't work. The other option they gave me was replacing both mirrors for about $300 each...no thanks. In your situation it could be a blown fuse, if not we might be on the same boat. Kinda sucks cause I replaced it with LEDs and I can't even use them
I've been having the same problem. My light actually flickers and it looks like I have a rave party in my car at night when I use them. I went to the dealer and asked them if they could fix it and they said that there is a switch inside of the visor that you have to enable...by doing that you have to mess around with the slider until the light turns on. I tried doing that and it didn't work. The other option they gave me was replacing both mirrors for about $300 each...no thanks. In your situation it could be a blown fuse, if not we might be on the same boat. Kinda sucks cause I replaced it with LEDs and I can't even use them ![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
I'll try your method first by playing with the slider to see if it'll hit any switch on the inside of the visor.
Thanks for chiming in dvo, it worked! I can't believe it, I just slide the puppy like 10-15 times on both sides and it just worked. Guess it wasn't the fuse afterall but very strange that this needs to be done in order to get it working. ![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Great tip/thread for pple having this problem. BTW, good luck with your issue dvo hope you get it resolved with minimum to no cost.
Registered User
MIne is also doing the same thing. I figured ill swap out the bulbs on the other visor and it still works.
So i know for a fact that it is the visor it self.
Now I wonder how to fix this problem.
It takes like 5-10x opening and closing the mirror to make the light work.
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
did you ever find out how to get this thing fix?
It takes like 5-10x opening and closing the mirror to make the light work.![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
No, I think I'm out of luck because I've tried sliding it back and forth and still no light. My passenger side still flickers now and then when it's on. I guess my only solution is to replace the visors with new ones...unless something else is wrong with my car that could cause my visors to do that ![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Registered User
I wish I knew how to work with wires, lol. I highly doubt that I will replace them with new ones just because I rarely use them and it doesn't bother me to the point where I would want to spend $600. But if for some reason I decide to get them I will let you know about the old ones.
