Pics of my '06 IS250 with 2011MY headlights w/ LED Strip
#122
The plug is for the LED and turn signal. The 2 little leads in the connector are for the turn signal while the 3 beneath are for the LED. This plug is apart of the headlight assembly, so it just connects to another plug that actually plugs into the LED board and turn signal bulb (which the cap you'd have to get for the bottom contain the wires for).
#123
what covers did you need to buy? Only the circle for the bottom?
do all cars come with afs built in even if we have halogen headlights? since you have halogens are you using that function? Or is that extra work that needs to be done?
#124
Anyone who has factory halogen doesn't have AFS.
#125
#126
No, nothing is removed from that separate connector. Its hard to explain without a pic of the entire headlight assembled with everything connected. Do you already have a 2011 headlight(s) in your possession?
#128
They're bright, but I wouldn't say overkilll at night. You can clearly distinguish both the low beam and LED at night.
#130
If you've got the $$$ I'd get them at Sewell to save the headache, otherwise try to find some used ones on eBay for much cheaper if you wanna take on the relatively easy project. I love them personally, very much worth it IMO.
#131
thinktwice, if you disabled the drl's from the dealer, doesn't that mean you don't have power for the leds? I was thinking how some people wanted the leds dimmer at night and came up with drl's in the day and when you turn on your headlights, the parking lights can power the leds at the dimmer setting? I'm a little confused..
#132
As far as the LEDs functioning at two different brightnesses, the way the LEDs in these headlights are setup is one wire is to power the dimmer intensity and another wire is to power the brighter intensity. So the trick is to figure out a way to have each wire powered separately and triggered when the low beam turns on. Not sure if that's possible though.
#134
Yeah for that price you might as well get new ones from Sewell. There was someone here who recently got both via ebay for only $820 shipped believe.
