How do I remove chrome window trim?
Old 04-30-11, 01:07 AM
CCJ22
CCJ22's Avatar
Default How do I remove chrome window trim?
I want to remove the chrome window trim so I can paint it.
No I don't want to plastidip it.
No I don't want to leave it on the car and mask everything else off and have it painted.
For reference it's the chrome trim on the exterior windows.
I don't mind breaking it to get it off then replacing with a new, already painted, window trim.
We were discussing this over on the "other board" but that forum fails to get as much traffic as this site does.
Does anyone have a helms manual that shows step by step how to replace the chrome?
Thanks in advance.
http://my.is/forums/f154/does-anyone...7/#post6430883
Old 04-30-11, 01:08 AM
IS250Kevin
IS250Kevin's Avatar
Get it vinyled.
Old 04-30-11, 01:29 AM
NorCal510
NorCal510's Avatar
+1 best bet is to get it vinyled. you can vinyl the chrome trim in gloss or matte, whichever you prefer.
Old 04-30-11, 01:55 AM
CCJ22
CCJ22's Avatar
Sorry, I've had bad experience with vinyl scratching easy.
I'd like to get them painted.
Old 04-30-11, 06:39 AM
ApokC
ApokC's Avatar
Just plastidip it lazy!!!
Old 04-30-11, 07:31 AM
ColtM4A3
ColtM4A3's Avatar
I have a vert so I don't have door frames to look at, I can try give you a general idea. I would start by looking to see if it runs under the side mirrors. If so, they will need to be removed first. Put the windows down and pull the weatherstrips out of both channels. You should be able to see if it appears to be snapped on to the door frame. Some cars will reveal rivets that will need drilled. If it's snapped on I'd start prying on the side with the smallest amount of overlap onto the door frame using a flat clip removal tool. Be careful when you get to flat part of the back of the door frame, it's likely that a small clip holds it flush up against that. If you're lucky it will be secured by a small screw which can be removed easier than a clip can be released but I wouldn't count on it.
Old 04-30-11, 10:12 AM
KvnChu
KvnChu's Avatar
a good vinyl typically shouldn't scratch easily... i would be more concerned with paint chipping...
but its up to you
Old 04-30-11, 10:15 AM
HERBos
HERBos's Avatar
plastidip is better easier cheaper good luck!
Old 04-30-11, 02:10 PM
edgeucated
edgeucated's Avatar
if he vinyls it he'll still need to take the trim off the car.
I haven't recall any DIY on this site that explains how to take off the chrome trim. The only people who I have seen have this done just took it to a shop. If you end up doing it yourself, it would be nice if you posted a DIY
Old 04-30-11, 02:31 PM
ChrISF
ChrISF's Avatar
you cant take them off. but sharpies are great!
Old 05-01-11, 12:58 AM
NorCal510
NorCal510's Avatar
^^ lol that'll just turn a dark purple afterwards!
Old 05-01-11, 02:31 AM
tenspeed
tenspeed's Avatar
I have successfully vinyled chrome window trim while on a car. Not on a Lexus but Lexus can't be any different from other cars.
You can get vinyl tape at the parts stores. I used Scotch 3M electrical tape. It's a quality vinyl that's 7 mils thick. I got it close on one edge and trimmed the other edge with a razor knife. Apply the tape without stretching it. Work from the rear to the front so any joints overlap. If you screw up, pull it up and try again - there's plenty of tape on the roll.
It's been on my DD for two years without any problems. I'm thinking of replacing it with matte vinyl this year.
Old 05-01-11, 09:49 AM
CCJ22
CCJ22's Avatar
So the trim isn't replaceable yet sewell sells the part? Interesting.
Old 05-01-11, 10:22 AM
HERBos
HERBos's Avatar
sewell sells everything...
Old 05-02-11, 09:05 AM
CCJ22
CCJ22's Avatar
LOL I'm beginning to see that.
Quick Reply: How do I remove chrome window trim?
