Oil filter wrench
Old 08-04-11, 04:20 PM
Dstockton
Dstockton's Avatar
Default Oil filter wrench
Do I need the oil filter wrench to change the filter on my IS 250 or do you all use a different device?
Old 08-04-11, 04:27 PM
chi123
chi123's Avatar
http://cgi.ebay.com/ebaymotors/Lexus...motiveQ5fTools
Something like that will work. Don't buy the ones available at Autozone. Their "F" cap is 65-67mm and is universal. I tried it and it kept slipping since my filter housing was overtightened from the dealer.
Old 08-04-11, 04:28 PM
kumquatism
kumquatism's Avatar
An oil filter wrench would definitely make your life easier, but you technically don't HAVE to use one. You just need anything to twist the housing to get it apart.
I use a generic one that looks like this:
Old 08-04-11, 04:36 PM
Bichon
Super Moderator
Bichon's Avatar
I highly recommend and personally use this one: http://www.amazon.com/Assenmacher-Sp.../dp/B0015PK3AG
heyarms
heyarms's Avatar
i use the "F" wrench, it does tend to slip some, and stick onto the housing other times... LOL.
Didnt know ^^^^ were able to be used/never tried it.
Old 08-04-11, 05:15 PM
isthrizzy
isthrizzy's Avatar
Ya, I just had to order a new filter wrench since I misplaced mine somehow.... it sucked because I already had the oil drained when I figured out I had no wrench. I'm a pretty strong guy and I couldn't loosen that filter without help.... so ya, I'm pretty sure you need a tool whether it's a generic one or Lexus specific.
Old 08-04-11, 06:40 PM
aarongue6
aarongue6's Avatar
I bought one from my local Toyota dealer for only $12 before tax.
Old 08-04-11, 06:47 PM
Gville350
Gville350's Avatar
X2!!! 10 char
Old 08-04-11, 08:12 PM
dsage
dsage's Avatar
Originally Posted by Gville350
X2!!! 10 char
x3 i got mine from a local snap on tool truck for $18
Old 08-04-11, 08:35 PM
HAiS250
HAiS250's Avatar
is that the right tool to open the oil filter housing?
if it is, i'll get it
Old 08-04-11, 09:46 PM
fdelement
fdelement's Avatar
just borrow a strap wrench and get it loose for the first time. When you put the housing back on just hand tighten it so next time you do it you can just use your hands. I hand tighten mine for 40k miles every 4k miles and never had a leak whatsoever.
Old 08-04-11, 10:14 PM
flowrider
flowrider's Avatar
Received 1,943 Likes on 1,369 Posts
To the OP, first off there are many many threads on this. Below are just 2 of them.
https://www.clublexus.com/forums/is-...er-wrench.html
https://www.clublexus.com/forums/is-...-question.html
A strap wrench may work, but it is not the proper tool. See threads above. And, you never never tighten an oil filter with a wrench, you always hand tighten them, then you use a wrench for the next oil change to get it off. If you tighten it so loosely that you can remove it with your hands on the next oil change, it's too loose and too cool. An oil change should always be done on a warm engine making the filter assembly too warm to touch.
Lou
Old 08-04-11, 10:48 PM
Jetfire
Royale with cheese
Jetfire's Avatar
x4, Assenmacher is worth it's weight in gold.
Old 08-05-11, 08:20 AM
Deegee
Deegee's Avatar
I got THE toyota wrench the mechanics use for 15$ on Amazon.com best there is, best there ever will be if you decide to do your own oil changes (which I recommend)
Old 08-05-11, 04:32 PM
jbjones85
jbjones85's Avatar
I got the OEM one as well pretty cheap off another forum member when I first got the car. 1000X better than the cheap autozone ones. If you do your own changes its worth it to get a good one in the beginning.
Quick Reply: Oil filter wrench
