Have a repair manual/diagram for moonroof module (the dial pieces are my issue)
Old 08-21-11, 05:49 PM
patrick323
patrick323's Avatar
Default Have a repair manual/diagram for moonroof module (the dial pieces are my issue)
Taking apart the trim for painting with a headliner replacement; Upon reassembling it the dial doesnt "notch" like it used to, rather it just turns freely. It also gives no power to the moonroof. Neither does it depress in and rebound freely. After troubleshooting it a million times, taking it apart and putting it back together...still nothing. All day, this freakin thing! I managed with enough pressing and turning and fiddling with it to get it to close and it seemed that when it closed I had put these parts for the dial in different alignment. Now that it's closed I'm not messing with it till I am not just going to be fooling around. When it closed was such a random moment (holding it together not mounted or assembled) that I cant duplicate it.
There is an outer dial, an inner plastic piece/dial, and a little ring that makes an electrical connection. Perhaps there's a spring that popped and I didnt realize (there is only one spring now, mounted inside the outer dial). I dont know.
If anyone would happen to have a pdf file or a link to materials showing/explaining the assembly and operation of this...it'd be appreciated.
Old 08-21-11, 07:51 PM
blacksc4
blacksc4's Avatar
would love to help same problem though, i replaced my motor but now my moon roof wants to act funny, one side goes up other side goes down, and its really confusing cuz some times ill get it to slide back a little bit, but only if im holding the tilt button, which makes no sense
Old 08-22-11, 03:52 AM
patrick323
patrick323's Avatar
If you have any luck figuring this out let me know!
I've contacted someone who said they might be able to help, i'll let you know if i get mine taken care of
Old 08-22-11, 06:23 AM
MarkBMC
MarkBMC's Avatar
Here's the electrical diagnostic that might be some help....
File Type: pdf
Old 08-22-11, 06:26 AM
MarkBMC
MarkBMC's Avatar
this is the removal instructions, but you might find something useful in it... particulary step 12?
File Type: pdf
Old 08-22-11, 06:28 AM
MarkBMC
MarkBMC's Avatar
Not sure whether this will help, but it's the page on adjusting the roof.
File Type: pdf
Old 08-22-11, 06:29 AM
MarkBMC
MarkBMC's Avatar
And now that I've posted all that for you I realize I jumped from one forum to another... all of those are for SCs... sorry.
JohnnyCake
05-11-12 04:42 PM
94GS300
GS - 1st Gen (1993-1997)
05-31-10 10:38 PM
uae
08-19-09 11:45 AM
shikbas
RX - 1st Gen (1999-2003)
11-02-08 05:58 AM
kattanh3
05-29-07 10:38 AM
Quick Reply: Have a repair manual/diagram for moonroof module (the dial pieces are my issue)
