is350 transmission fluid
Old 12-30-11, 12:44 AM
is250fsprt
is250fsprt's Avatar
Default is350 transmission fluid
The service guy at Lexus of Tacoma in Fife said the is350 never need a transmission drain and fill. Is he full of crap or is this true?
Old 12-30-11, 01:28 AM
KillaIS250
KillaIS250's Avatar
This is true, our cars use the World Standard ATF fluid which is a lifetime fluid that doesn't need to be changed. The transmission on our cars is a sealed unit that wasn't designed to be serviced either. There are ways to change the transmission fluid if you want, but its unnecessary. The only thing you need to do with the transmission should be to inspect for any leaks. There is a member here that has 250,000 miles without changing the ATF so its been proven to last that long i guess
Old 12-30-11, 01:30 AM
dorkacho
dorkacho's Avatar
Wow, I keep finding out awesome things about our cars, thanks for sharing
Old 12-30-11, 01:52 AM
is250fsprt
is250fsprt's Avatar
Thanks for the reply.
Old 12-30-11, 01:58 AM
KillaIS250
KillaIS250's Avatar
Np guys!
I was worried about the transmission servicing too when i got my IS250 because i've had transmission issues in the past with my Prelude and was changing the ATF every 30k. Glad our transmission doesn't need servicing and has been proven to last tho
Old 12-30-11, 08:23 AM
Gville350
Gville350's Avatar
The diff fluid I believe is also lifetime.
Old 12-30-11, 03:40 PM
Slammer1
Slammer1's Avatar
I was also told the same when I inquired about the proper fluid. The dealer said that the only time they drain the fluid from the trans is when they are making a trans repair. NOT as a preventive maintenance service. No worries!
Old 12-30-11, 08:06 PM
KillaIS250
KillaIS250's Avatar
Yep and that's why you wont see it in the service schedule either
Old 10-02-23, 08:14 AM
jonyen
7th Gear
jonyen's Avatar
Don't buy into "lifetime" fluid as it only a marketing gimmick to keep the costs of ownership to down. All fluids will breakdown over time.
maurice01
11-24-19 02:48 PM
mbaker7
04-16-12 03:54 PM
chinalfr
Hybrid Technology
07-18-11 10:26 PM
Bobk528
RX - 1st Gen (1999-2003)
16
09-26-05 07:34 PM
Quick Reply: is350 transmission fluid
