3M Headlight Restoration
Old 04-08-12, 06:49 PM
dangp
dangp's Avatar
Talking 3M Headlight Restoration
Car: 2006 IS250
Problem: Headlight oxidation and hazy
Solution: http://solutions.3m.com/wps/portal/3...g_a_Headlight/
Est. Time: 45-1hour (considering this is my first time doing it)
Outcome: It works. Watched a youtube how-to video made it easy.
Old 04-08-12, 10:36 PM
jaytido24
jaytido24's Avatar
very nice..i was thinking bout getting some every time i pass a bottle of this stuff at the store...this might be my weekend project next weekend.
Old 04-08-12, 11:34 PM
KillaIS250
KillaIS250's Avatar
Very nice. Now get something like Meguairs Headlight protectant to keep them sealed from all that UV damage or the headlights won't stay like that for long. Looks like this...
Amazon Amazon
Or you can just wax the headlights. I waxed mine constantly after I did the sanding method on my old car and they stayed like-new for a lot longer than people I know that just sanded it and left it.
Old 04-09-12, 12:43 AM
stasis3131
stasis3131's Avatar
Or if you got a ultra steady hand just clear coat the headlights after you restore them . I did that and they look awesome
Old 04-09-12, 04:28 AM
Bichon
Super Moderator
Bichon's Avatar
Consumer Reports did a test of these in March. Their top pick was the Sylvania Headlight Restoration Kit. That kit doesn't require an electric drill, and comes with a UV blocking clear coat that is applied as the last step.
The 3M kit that dangp used was their second choice.
Old 04-09-12, 05:34 AM
ibidu1
ibidu1's Avatar
Problem you will have now is that you most likely sanded away the factory clear coat on the headlight. Your headlights will fog up faster now.
Sanded the headlights would have been if your headlights were really foggy and normal buffing wouldnt shine them back up.
Old 04-09-12, 05:52 AM
Tendi23
Tendi23's Avatar
I used the 3m and they fogged up 6 months later.
Old 04-09-12, 07:43 AM
kikcaffine
kikcaffine's Avatar
I just hit mine with rubbing compound and they came out looking good.
Old 04-09-12, 09:07 AM
Sconnie
Sconnie's Avatar
If you use the 3M kit, skip the most abrasive pad. This is EXTREME overkill for a little haze. I would only use if you are trying to take out a deep scratch or gouge.
I did this to my G35. As noted above, it looked great and then fogged up right away...
Old 04-09-12, 09:43 AM
Hoovey689
Hoovey689's Avatar
excellent work. gotta do this to my driver side headlight
Old 04-09-12, 10:26 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
the one from rainX also comes with the sealant....
Old 04-09-12, 12:20 PM
eyezack87
eyezack87's Avatar
Just an observation, but it appears that the issue with your lights was oxidation, not major swirls or anything. If there are minor swirls and oxidation, it would have been better to just polish them instead of going the whole 9 yards. As a detailer, all I can say to anyone else is: always use the least abrasive step first
Old 04-09-12, 12:25 PM
p0lo8
p0lo8's Avatar
I used Sylvania and it worked like charm
Old 04-09-12, 12:33 PM
Magicks
Magicks's Avatar
Have you guys tried toothpaste + wax?
Old 04-09-12, 12:48 PM
stasis3131
stasis3131's Avatar
The tooth paste thing works great.
I have a door jam gun/touch up gun that I use to spray 2 coats of clear over the headlights after then are done. They look factory when done and last ultra long. My neighbors bring over their cars all the time for me to do theirs. I have used rattle can clear before. Works good just take your time cause it runs easily
Quick Reply: 3M Headlight Restoration
