6 Ballast Little Scared
Old 05-23-12, 08:29 AM
Kumar350
Kumar350's Avatar
Default 6 Ballast Little Scared
Hey guys,
About to start tackling my next project for car. I want to swap all of my lights to HIDs/LEDs now I know if I go the HID route and i change out my Head Lights, DRL, and Fogs I will be dealing with 6 yes SIX BALLAST and I was wondering if there is any way around that.
I was maybe thinking going with LEDS for some of them but dont know which ones it go with LEDs and which ones to go with HIDs can I get some help. The look im going for is the all white look so im either buying 4300k or 6000k.
Price is an issue but not cheap. BALLIN" ON A BUDGET
Old 05-23-12, 10:10 AM
evogt500
evogt500's Avatar
There is no way around having a ballast for each bulb. However, why do you want HIDs for your high beams? They will disable DRL and they wont last long.
Old 05-23-12, 10:56 AM
Kumar350
Kumar350's Avatar
Ok well what do you suggest I should use for high beams? LEDs? Im new to the modding world so still learning.
Old 05-23-12, 11:12 AM
vboi4life
vboi4life's Avatar
i just did change all my headlight ,drl,parking light to 6000k.The fog i take the front bumper off.it look hard but not really hard when you do it.here is detail what i have
head light 6000k garax
parking light vled 6000k 4 flat led
vled new module with 28 led(lose high beam)
fog light 6000k hid
i just do some diy for fog and drl on at same time.guess what now my drl stop working.i will fix it at another time.
Old 05-23-12, 12:18 PM
Kumar350
Kumar350's Avatar
So there is a total of 4 sets of lights on the front of the car that CAN be changed???
Correct me if im wrong I thought there were only 6
(1)Headlights
(2)Daytime Running Lights
(3)Fogs
Old 05-23-12, 12:27 PM
evogt500
evogt500's Avatar
LEDs will be aesthetically pleasing. However, light output is low. I remember another CL member was complaining his low beam was brighter than his hi beam. Turns out he had LED high beams.
You can choose colored halogen bulbs, but they might not match your low beams.
LEDs are basically for looks only and will not "function" as high beams.
HID will be bright, but they need time to warm up, so you cant "flash" your high beams to
others.
The choice is yours.
(1)Headlights
(3)Fogs
DRL's are high beams on low power. If you change your DRL, you change your high beams.
There is a city light/parking light integrated in the high beam housing. Is that what you are talking about? You can change that bulb to LED.
Old 05-23-12, 01:18 PM
Kumar350
Kumar350's Avatar
others.
(1)Headlights
(3)Fogs
Ok so tell me how this sounds......
If I put HID for my DRL/High Beams andmy city/parking lights I do LED and the fogs i do HID. Do I have all the stock lights covered?
Old 05-23-12, 03:24 PM
cre8
cre8's Avatar
HID for DRL/HI Beams will lose HI Beams due to the fact that bulbs operated two stages.
If I were you and I want to operate all the light to fully operate I will change,
Low Beams with Garax 8000K.
Change HI Beams and DRLs with this one.
http://www.nigel-jdmparts.com/Nokya-...ht-bulbs-7000k
City/Parking Light with this one.
http://www.nigel-jdmparts.com/LED-Bu...ddle-light-etc
Fogs will be any HIDs with your choice of brands.
I hope that helps.
Old 05-23-12, 03:27 PM
evogt500
evogt500's Avatar
For the most part. If you want to be technical, there are 2 more turn signal bulbs per headlight and a side marker bulb. By the way, this is only for 2006~2010 models.
Old 05-23-12, 03:50 PM
cre8
cre8's Avatar
Side Marker Light in 2006~2010 Model ? Mine is 07' and no where to found those side marker light. I wish I want one. Ofcourse one on each side.
Old 05-23-12, 04:35 PM
evogt500
evogt500's Avatar
Sorry, I don't know if its actually called a side marker light, but its the amber bulb that lights up the reflector in the headlight housing.
Old 05-23-12, 07:01 PM
llamaboiz
llamaboiz's Avatar
Heres a question, do you live in city or sticks? do you use hibeams at all? I never have need to use hibeams so i just run LED 9005's.
Old 05-23-12, 07:05 PM
es808
es808's Avatar
FYI. The amber side markers in the headlights are LEDs. These are soldered to a board and can be changed only by taking apart the headlights and desoldering the LEDs. They're not a plug in bulb.
Old 05-23-12, 07:35 PM
evogt500
evogt500's Avatar
At first I thought so too, but in thr service manual it is stated as wedge base type bulb. Maybe its a typo. Attached jpeg of service manual diagram.
Old 05-24-12, 11:43 AM
cre8
cre8's Avatar
Those side turn signal light only available in JDM? I saw some member from CA was doing that light after market. Correct me if I am wrong.
Quick Reply: 6 Ballast Little Scared
