Found Flyaudios Manufacturer
Old 12-07-12, 10:30 AM
  #631
gaccord32
gaccord32's Avatar
I am waiting for my unit to be delivered and I was wondering if there was a sub out on the unit that I could run my subs off of it.
Old 12-07-12, 11:23 AM
  #632
SNORTH350
SNORTH350's Avatar
Installed the FA unit in my car, I know this isnt the FA thread, however this thread is more active. Heres my problem... My unit is great, the backup camera is excellent... but at night I get little to no visibility on my screen.... It almost looks like a haze, Im not sure how cars with factory backup cameras are set up, or they get more light. Any ideas? Anyone else having this problem?
Old 12-07-12, 11:40 AM
  #633
nosurprise
nosurprise's Avatar
I haven't put in a camera, so I'm not sure, but it might be a defective camera.
There is no sub output. It basically uses whatever that comes with the car -- it adds a DVD, a screen, and nav (and video and audio output cables, but those are RCA connections).
Old 12-07-12, 11:43 AM
  #634
SNORTH350
SNORTH350's Avatar
Its not a defective camera I dont think, its just not collecting enough light! Im not sure if the factory Nav IS car has additional brake lights.
Old 12-07-12, 11:52 AM
  #635
nosurprise
nosurprise's Avatar
I shouldn't said defective ... what I mean is a bad or sub par camera. You can try swapping it out to see if it makes a difference.
Old 12-09-12, 11:42 AM
  #636
nosurprise
nosurprise's Avatar
Does anyone know what the original temperature setting range in Fahrenheit is for the AC? I'm working with someone that might be able to fix this Celsius display issue, but he might need this information. It should be the highest/lowest number before the unit says "HIGH" or "LOW" and no more adjustments possible.
I might post this else where since probably everyone here already have their setting in Celsius lol
Old 12-09-12, 12:06 PM
  #637
Damaster32
Damaster32's Avatar
quick question as I wait for my unit to get here also.
Will my satellite radio still work?? or do i have to get a different receiver??
Old 12-10-12, 07:53 PM
  #638
tenaciousF
tenaciousF's Avatar
Has anyone gotten the unit to fit 100% correctly in an 06-08 with the new vents yet?
Old 12-11-12, 07:04 PM
  #639
bonroad
bonroad's Avatar
Default yes
Originally Posted by NimaM
I don't see why it can't be installed on an IS350. Maybe they don't have IS350s in China and the seller has no idea about the IS350!
No guy have bought it for IS350,so no one knows exactly.
If someone can check all cables in his IS350 and compare with Roadrover is250 dvd,things will be easier
Old 12-11-12, 07:31 PM
  #640
bonroad
bonroad's Avatar
Default they are the same item
Originally Posted by Guccimane
thank you, for you answer
But who have 06-2008 car year, please said about units, Is there a difference in color?
You can choose blue or orange colour according your need.
Old 12-11-12, 11:17 PM
  #641
TUNG
TUNG's Avatar
Check this link
https://www.clublexus.com/forums/is-...fitment-3.html
Go to post #41 and there is a member that had the unit fit with the 09+ vents just with some modifications.
Old 12-12-12, 01:49 AM
  #642
blui2
blui2's Avatar
Originally Posted by TUNG
Check this link
Re above comment ^^^ I bought this person's vents from him, think he went back to stock or changed his car (Cant remember which) and he sold me the vents for approx $80. I was looking for vents, but no one has been able to get the Nav and vents to fit in a 2006-08 perfectly. I think its to do with the angle of the chamber behind the vents being different in 06-08 than in 09+
The vents ive bought have been butchered to within an inch of their life but i bought them because he could provide photographic evidence of the fitment. I havent bought the nav yet, too close to Christmas for big spend but have spoken to LSQ and was quoted $640 for Unit, Camera, Igo 9 on SD Card, Shipping to UK and Paypal Fee.
Once i get the unit in New Year and get it all fitted, ill take pics. In meantime, the person i bought it from, the poster of #41 in other thread, is the perfect person to ask how to cut the Vents to make them work in 06-08. The vents he supplied to me are heavily modded!
Hope this helps - Can be done, but very difficult to get fitment right.
Old 12-12-12, 04:59 AM
  #643
Damaster32
Damaster32's Avatar
I ordered mine late November and its still on back order till, end of December. Just spoke with LSQ
Old 12-12-12, 12:10 PM
  #644
M88JCP
M88JCP's Avatar
Hi everyone
Following the above, it was myself that had the 09 nav fitted to my 07 car and the vents and nav DID fit perfectly.
I had nothing to go by when I adapted and fitted the vents to fit my car, so had to use abit of enginuity.
To get the vents to fit, you need to trim approx 15-20mm off the very rear of the vents. The two inlets that connect into the dash outlets (very back of the dash where the hot air comes out) are a different diameter and distance apart to the original 06-08 vents. If the compare the back of the new and old vents you will see what I mean. blui2 can verify this and its what I did to the vents I sold him. The only reason i sold them was because I've just brought a brand new AMG Mercedes.
Hope this helps and dispels the myth of, the new vents won't fit an 06 car. Its not true. They WILL fit if you trim the very back of the two vent inlets. The reason they don't fit unmodified is becuase they are too wide for the outlets in the back of the dash and the new and old parts fight to seperate and push against themselves. Trim about 10mm behind the foam padding around the inlet. To try and be more specific, when you close the vents ie the airflow flaps, the cut should finish just behind where the flaps touch the inlets.
Maybe blui2 can post a picture of the vents I sold him
Old 12-12-12, 12:16 PM
  #645
jsmacks
jsmacks's Avatar
When you say the vents and your nav fit "perfectly".. are you saying that you had zero gap? Can you post pictures of what your "perfect" fit looks like? Very curious as this is what is stopping me from doing this in my 08.
Quick Reply: Found Flyaudios Manufacturer
