Just added another Smart Card key to the car (DIY instructions included)
Old 10-19-12, 06:14 PM
sutekidane
sutekidane's Avatar
Default Just added another Smart Card key to the car (DIY instructions included)
Hi all, I recently picked up a 2006 IS350, however the seller only had one remote to the car.
So I ordered two additional new Smart Card key to register to the car through the use of the "aftermarket" M-VCI cable.
Please keep in mind, there is no way to program used keys/cards without additional expensive hardware/software.
So these steps only work for brand new never been programmed cards/keys.
:: DISCLAIMER ::
These instructions are provided as a reference for you to refer to adding additional remotes to the car.
These procedures worked on my vehicle, however your miles may vary, therefore, I am, in no way, responsible for any damages caused in the process.
Please do not continue reading if you do not agree!
Stuffs you will need:
(1) - NEW, never programmed , Smart Card Key (parts # 89904-50641)
(1) - 32-bit Windows XP/7 laptop with Toyota Techstream installed
(1) - M-VCI USB to ODBII Cable with 32-bit drivers installed
(1) - Original programmed remote for the procedures
This is how a brand new, never programmed, found on eBay.
Just added another Smart Card key to the car (DIY instructions included)-fomox.jpg
This is all the stuffs you need in order to program the key:
Just added another Smart Card key to the car (DIY instructions included)-r2agi.jpg
Location of the OBDII plug, it is right above the brake pedal with a black cover
Just added another Smart Card key to the car (DIY instructions included)-r5bmg.jpg
Run Techstream, and click on "Connect to vehicle"
Just added another Smart Card key to the car (DIY instructions included)-1fsa1.png
After initialising, this will show up, pick OTHER if you do not have radar cruise, then press next
Just added another Smart Card key to the car (DIY instructions included)-ah3sj.png
Then double click on Smart Access
Just added another Smart Card key to the car (DIY instructions included)-syewj.png
Then click on "Utility" on the left hand side
Just added another Smart Card key to the car (DIY instructions included)-ad5zq.png
Then click on "Smart Code Registration"
Just added another Smart Card key to the car (DIY instructions included)-slk1l.png
Then check all the boxes and press next,
Just added another Smart Card key to the car (DIY instructions included)-wyqlx.png
Then Techstream will inform you how many slots are available and taken,
Just added another Smart Card key to the car (DIY instructions included)-2mojj.png
Then Techstream will inform you to place both new and programmed remotes outside of the vehicle. Press next
Just added another Smart Card key to the car (DIY instructions included)-dtat0.png
When you are ready, press Pre-Start CHK to enable the Start box, and quickly tap the registered remote to the ignition botton in the vehicle with the L logo facing it.
Just added another Smart Card key to the car (DIY instructions included)-otnza.png
Then quickly place the original remote outside of the vehicle and tap the smart card to the ignition button
Just added another Smart Card key to the car (DIY instructions included)-f4gva.png
Lastly, congratulations, you have successfully programmed the smart card to the system
Just added another Smart Card key to the car (DIY instructions included)-w6z4j.png
The following 2 users liked this post by sutekidane:
kelleher2 (10-05-17), nigel821 (07-21-21)
Old 10-19-12, 07:28 PM
rookieIS
rookieIS's Avatar
good writeup
Old 10-19-12, 08:16 PM
iNfectious
iNfectious's Avatar
Nice! I keep this thread in mind in case I need to program additional keys. I bought the software/hardware a while ago for the personalization settings.
Old 10-19-12, 09:43 PM
NimaM
NimaM's Avatar
Subscribed! Thanks for such a great thread!
Old 10-19-12, 10:41 PM
jbounnoi
jbounnoi's Avatar
Good write up!
Old 10-19-12, 11:06 PM
hypermyk
hypermyk's Avatar
Nice write up
Old 10-20-12, 07:49 AM
JETLEX
JETLEX's Avatar
Thank you for posting!
Old 10-20-12, 08:53 AM
TravyTrav
TravyTrav's Avatar
Can anyone download that ToyotaTechStream?
Old 10-20-12, 11:30 AM
nielsio
nielsio's Avatar
no illegal software link please
Old 10-20-12, 05:53 PM
es808
es808's Avatar
Very nice write up! Now I need to get one of these for my TPMS and extra key. Thanks Sutekidane!
Now someone needs to do a write up on the TPMS programming...although I don't think it will be that hard.
Old 10-21-12, 12:32 PM
iNfectious
iNfectious's Avatar
You can find and download the software. After that you can buy a subscription or find out how to get a free key. Search the Toyota Tundra forums. Finally you need the cable.
Or buy the kit from China mentioned in the other thread.
Old 10-24-12, 12:29 PM
B16da9
B16da9's Avatar
Old 10-24-12, 02:18 PM
sutekidane
sutekidane's Avatar
I bought a programmer just like that from Shenzhen, too, but the programming procedures are not as intuitive as it sounds, as timing is really, really critical. Plus, the idea of erasing all keys from the system to begin the process is rather risky with an aftermarket device without any support. Let's say what if it something happens in the process and you are stranded without ANY keys at all to start the car with? Not to sound like a hypocrite, but I understand that the M-VCI cable is also an aftermarket device without any tech-support, but it has been proven that it works, albeit slow, but I rather have an official GUI interface telling me what's going on rather than with a LED blinking telling me to look it up on the spec-sheet.
Old 01-01-13, 12:50 PM
slowpoe3
slowpoe3's Avatar
This is some good info to read and know about.. good write up.
Old 01-01-13, 08:23 PM
Skyfox16
Skyfox16's Avatar
Agree! Hopefully someone will do the TPMS before summer comes around.... i need to add a second sensor for my new wheels.
Also, Thanks to the OP for posting this. Now i just need to find a smart key
Quick Reply: Just added another Smart Card key to the car (DIY instructions included)
