Sparkplugs Done with RPM Irregularity
Follow up to my CSP question thread earlier in the week:
Just got the sparkplugs done my IS 250 AWD as a result of the CSP diagnosis, as it was 20k miles overdue and they were original with the car. The car started up fine but the RPMs were sitting around 1500-1800 RPM when it first starts up and sits at 1000 RPM during idle while the car is in drive.
I decided to reset the ECU by pulling the negative terminal on the battery and let it stay unplugged for a little over 10 mins before replugging it back on. I think the RPMs should be okay now (as I started it after putting the terminal back on the battery), but I'll have to drive it around to check.
Has anyone had this kind of RPM irregularity after having you sparkplugs done?
I had a mechanic outside of the dealer work on the car. They're a family friend that owns a business out in West Palm.
I just noticed that the power windows don't go up or down automatically anymore.![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
EDIT: Thanks to the FAQ sticky, the windows go up and down automatically.
Can't be normal. Take it back, explain the situtaion and ask him to check everything out otherwise you are going to have to pay another mechanic or dealer to work on it. A family friend would want to know about the problem.
After driving around the car is behaving more normally while moving (RPM wise) and the idle RPMs are sitting at 1000 now in Park and around 850-900 RPM in Drive. I think the ECU is re-learning how to utilize the new spark-plugs.
If the battery was disconnected, then the ECU would be relearning. Nothing to be afraid of, let it do it's thing and it will be good while the RPM's adjust.
Probably noticed, too when you tried ot start the car after staring the, you have to start it twice.
Two other things to note.
You have to open and close each window fully the auto open works properly.
Any Tacho and Speedometer indicator settings you have customized before is reset back to the default values.
I did notice that it took me two times to start it up after putting the battery back on which freaked me out initially and I opened and closed all my windows after finding out that they didn't automatically go up or down.
I was surprised that my navigation, radio settings, and trip counters survived after the battery being disconnected. Though my MPG AVG, Tank AVG, and clock were the only things affected along with the windows.
For the 2008+ cars, they got built in memory for the windows so that is one less thing you have to set back.
An update: upon further inspection, I found that the the rubber tubing that goes from the intake to the throttle body was crimped in a way where it probably messed with the air flow into the manifold. So, I took apart the intake and reinstalled it properly. And I decided that it would be best to reset the ECU (again, via fuses instead
Idle RPM in P: ~1100-1200
Idle RPM in D: ~900-1000
I'm hoping that those idling RPMs will drop back to the way they were before the service.
The change to the windows happened for the 2009 model year, not 2008. The entire control system was updated, including adding variable speed (the windows slow down as they reach the end of their travel). On the newer vehicles there is no need to reset the windows after disconnecting the battery.
Jeff
Jeff
I'm still scratching my head on why the RPMs are still rather on the high side, but I'm digging the responsiveness of the car after getting the sparkplugs done. I need to drive it more and let the ECU get used to everything and hope that is the case.
I figured out the issue to my idling RPM issue, it was my throttle body that was giving me that issue. I took my intake apart and pushed the throttle plate back into the neutral position that is parallel to the circular openings and my RPMs are back to normal.
