2007 IS350 dead. Code P0200. P1235. Any Help??
Old 02-02-14, 05:08 PM
jasonr
jasonr's Avatar
Default 2007 IS350 dead. Code P0200. P1235. Any Help?? update. problem solved
Hey guys any help. My car just stalled and doesnt start. if i unplug the battery it does start then stall again. i can hear some sound under the intake manifold. I was able to drive but kept stalling.
Attached Thumbnails 2007 IS350 dead. Code P0200. P1235. Any Help??-untitled.jpg   2007 IS350 dead. Code P0200. P1235. Any Help??-car-result.jpg
Old 02-02-14, 06:06 PM
Serifiyah
Serifiyah's Avatar
Maybe this thread can help..
https://www.clublexus.com/forums/is-...ode-p1235.html
Old 02-02-14, 06:10 PM
jasonr
jasonr's Avatar
I dont know the location of CONNECTION AT DIRECT FUEL INJECTION DRIVER.
He didnt have P0200, P0204.
Old 02-02-14, 09:27 PM
panda08
panda08's Avatar
sounds like your direct injection fuel pump isn't operating normally?
Old 02-03-14, 08:30 AM
idoke1
idoke1's Avatar
Hmmm....injector circuit malfunction? What i would do is look for cylinder 4 and find the injector. Trace it's wiring. Could be a loose plug, a short in the wire or your injector may need to be replaced.
Old 02-03-14, 08:58 AM
MoeSzyslak
MoeSzyslak's Avatar
I doubt its the injector, the car would still run but like crap.
Leading up to this, were there any issues that happened that you recall? Any weird idle, rough starts, anything at all you can mention?
Old 02-03-14, 10:26 AM
mikellucci
mikellucci's Avatar
Did you by chance replace your waterpump or do any work there? Check the injector driver ecu box at the front of the engine- did one of the 4 connectors work loose or similar?
Vulkan (04-24-21)
Old 02-03-14, 12:28 PM
Gville350
Gville350's Avatar
If you are handy with a wrench and DIY, I'd recommend moving the #4 DI to another cylinder and see if the CEL code follows that DI or statys with that cylinder. It'll help narrow down the root of the problem.
GL...I HATE electrical issues!
Old 02-03-14, 06:51 PM
jasonr
jasonr's Avatar
thanks guys. well i dropped my car at dealership. I just got it like 20 days ago. I switched from IS250 to this one. so i will post the update.
Old 02-03-14, 09:25 PM
idoke1
idoke1's Avatar
Keep us informed. I'm curious to see what the problem is
Old 02-05-14, 05:36 PM
jasonr
jasonr's Avatar
Default problem solved
Here is the result.
Attached Thumbnails 2007 IS350 dead. Code P0200. P1235. Any Help??-car-result.jpg
Old 02-05-14, 07:55 PM
Gville350
Gville350's Avatar
^Glad it was a simple fix!
lexpilot
11-08-17 02:18 PM
bronz
06-28-16 10:48 PM
kl323
12-25-13 05:40 PM
Pennies350
10-29-13 04:36 PM
Quick Reply: 2007 IS350 dead. Code P0200. P1235. Any Help??
