What vin's have carbon build up issues?
Old 03-03-15, 02:33 PM
20LS01
20LS01's Avatar
Default What vin's have carbon build up issues?
Hi,
I am new to the forums.
I am looking at a 2008 is250 RWD this weekend. I found a PDF that shows the range for VINS that could potentially have the carbon build up issues. This PDF only refers to vins with "BF" in them but the car i am looking at has BK in the vin. Are vins with BK exempt from this issue?
What is the difference between BF and BK in the vins?
Thanks for your help, hope i can haul one in this weekend!
File Type: pdf
Old 03-03-15, 03:27 PM
CMACE23
CMACE23's Avatar
My 08 IS250 had the campaign done and I have a "BK" vin. I'm pretty sure its open to any second gen IS250. Should be 9 year unlimited millage If I'm not mistaking.
Old 03-03-15, 04:45 PM
ianbis
ianbis's Avatar
From what I've read, the issue is with the direct injection system that is employed in the is250. In a direct injection system fuel is injected directly into the cylinders at a high pressure below the intake valves.
Fuel injection systems operate at extremely high pressures and carburetors operate at lower pressures.
In a none direct injection system (regular fuel injection) the fuel and its' detergents "washes" the intake valves as it is sprayed at an extremely high pressure so that the fuel cleans the intake valves as it swirls its way past them on its' way to the cylinder which effectively mitigates carbon build up on the valves and its' ensuing expenses and headaches.
In a carbureted system the fuel washes the intake valves as described above but at a much lower pressure.
In the is350 there is direct injection of fuel straight into the cylinders below the intake valves but there is an additional fuel injector mounted above the intake valves that "washes" and mitigates carbon build up as described above.
Old 03-04-15, 10:56 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
It applies to all 2006-2009 models and 2010 models before the VIN's listed.
The VIN formatting changed for 2010 models (pretty universally across all Toyota/Lexus/Scion models). 2006-2009 models have BK in the VIN, 2010 have BF.
Jeff
Old 03-04-15, 12:30 PM
20LS01
20LS01's Avatar
Jeff
the last 7 of the VIN ends with 5050882, does this mean this engine falls into the range that could have the carbon build up issue?
Old 03-04-15, 12:39 PM
CMACE23
CMACE23's Avatar
All IS250's could have the carbon issue. I'm pretty sure even the new 2015 IS250 has the same engine. Gonna be pretty interesting to see when they start to kunk up.
Old 03-04-15, 12:43 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
All 2006-2009 IS250's are within the range.
Jeff
Old 03-04-15, 02:21 PM
20LS01
20LS01's Avatar
Jeff
i thought ive seen vins over that range but i could be wrong. Thanks for info. Either way, i think i read there is a 9 year warranty with unlimited miles, so i will still have about 2-3 years of warranty. Im excited! If i purchase, anyone care to see more stock lexus pictures?
Old 03-04-15, 05:27 PM
sktn77a
sktn77a's Avatar
Agree. As long as the IS250 engine has only direct injection there is no reason to think that they aren't ALL susceptible to carbon buildup.
surensm
07-22-21 07:51 AM
Jls160
03-31-19 07:22 AM
LanceK
01-29-19 07:30 PM
Kapitanemo
03-20-17 01:00 PM
trippy
08-22-16 09:22 PM
Quick Reply: What vin's have carbon build up issues?
