battery replacement now tons of codes.
Old 05-18-15, 10:28 AM
prowler9
prowler9's Avatar
Default battery replacement now tons of codes.
Hey all.. New guy here to a new car.
I had to replace the battery the other day in my 2008 is250. It dies and sat for about 4 days before I got a chance to replace. I purchased a battery from Advanced Auto (got the gold). Ever since the battery replacement I have had 4 codes popping.
Error Codes:
C1241 (low or high power supply voltage )
C1201 (engine control system malfunction )
P2009 ( intake manifold runner control circuit low bank 1)
What should I do? Do you think it is a bad battery? Charging system?
The car runs and drives just fine. I had them clear the codes but they came back on.
Thanks for any help!!!
Old 05-18-15, 05:53 PM
prowler9
prowler9's Avatar
anyone at all? Any idea where to start?
Old 05-20-15, 06:30 PM
prowler9
prowler9's Avatar
wow.. 111 views and no reply...:-(
Old 05-20-15, 06:40 PM
smokyis350
smokyis350's Avatar
Try unplugging the battery and leave it off for 10 minutes then put it back on
Old 05-20-15, 06:58 PM
G4lexboi
G4lexboi's Avatar
I just replaced my battery with an Odyssey battery...no problems here.
Old 05-20-15, 07:45 PM
smokyis350
smokyis350's Avatar
I just replaced mine last month with Costco brand one. No problems here either
Old 05-21-15, 09:43 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
try 30+ minutes.....you'll need at least 30 min to reset the codes....
Old 06-14-15, 08:27 AM
VTsuckah
VTsuckah's Avatar
When I replaced my battery recently, the car turned over, but didn't start. The check engine and traction control ligts lit up. I disconnected the negative battery terminal for 15 or so minutes and reconnected. Everything was kosher afterwards. It's common for this to occur.
bakehot82 (08-02-20)
Old 06-14-15, 10:33 AM
sthakor92
sthakor92's Avatar
Codes are still off! I drove it a bit earlier and felt like there was more resistance on the highway.. But that was probably in my head.Thanks!
Old 06-15-15, 10:06 AM
pheonix72
pheonix72's Avatar
Since the power was cut off as you replaced the battery, the ECU is in the process of relearning your driving style/pattern. Keep driving as you normally do and it will settle in. Hopefully the codes wont come back.
Old 06-15-15, 01:56 PM
sthakor92
sthakor92's Avatar
Today while i was at the bank in the drive thru i put it in park and the car started shaking... Stepped on the gas a bit and it went away but it kept coming back. Tried it while in drive and no shaking. I also just took it to the auto store to see if the battery is good and it checked out okay
Old 06-15-15, 02:34 PM
pheonix72
pheonix72's Avatar
You didn't mention why the battery needed to be replace? I think you have a bad alternator (and it caused your original battery to go bad in the first place). Have the shop check the alternator to see if it is putting out the proper voltages.
Old 06-15-15, 05:06 PM
sthakor92
sthakor92's Avatar
I didn't replace the battery, I jumped it and its been working... I'll have them check the alternator
Romanova
08-17-19 12:19 PM
sfgent
04-19-19 03:49 PM
ak11
08-06-12 11:25 AM
OnlyVice
11-20-11 02:34 PM
intellis
05-12-11 03:41 PM
Quick Reply: battery replacement now tons of codes.
