F Sport wheels - touch up paint ??
Old 11-27-13, 09:40 AM
jaznraz
jaznraz's Avatar
Default F Sport wheels - touch up paint ??
Is there a paint available that matches the 2014 F sport wheels? Is the wheel color the same as previous years? Read on for the unfortunate story....
When mounting winter tires on the factory wheels today, the tire store chipped the paint on one wheel. They offered to fix it professionally, but I would have to be w/o wheels (and the car) for a couple of weeks while they refinished the whole wheel. I was doubtful that the repaired wheel would match the other wheels, so I got my money back for the mount/balance and decided to fix it myself.
To compound my frustration, they found a nail in the sidewall of the factory rear summer tire. I got the car on Saturday.....4 days and 384 miles later, I have a damaged wheel and a destroyed tire. Ugh.
Old 11-27-13, 10:18 AM
jashishi
jashishi's Avatar
Sorry to hear that man. I recently got a minor curb rash on my Fsport wheels too, 600 miles on the IS350F.
I think I will be fixing it through a professional with paint match as it is small. About $50-75.
I've read that others have said Duplicoat's Wheel Coating - Graphite works okay enough for a gunmetal wheels. Googled a pic below.
http://www.duplicolor.com/products/wheelCoating/
Old 11-27-13, 11:46 AM
afdavey
afdavey's Avatar
Don't forget to use the 'clear coat ' to finish them off...
Old 11-29-13, 05:30 AM
jaznraz
jaznraz's Avatar
Thanks for the info, I will check out the DupliColor wheel paint. Luckily, the chip is very small (2mm).
Old 12-06-13, 04:16 PM
noosense00
noosense00's Avatar
Went to a reputable shop today to get my winter tires mounted and I came back with two small chips (one on each tire) which I am not happy about.
I spoke to the owner and he said the wheels are extremely sensitive to any pressure such as the tool used to put the tire in. I guess the paint on the rims are extremely soft.
For those who are getting there tires changed, make sure the shop is extremely careful with them.
Old 07-12-17, 02:35 AM
dbin1991
dbin1991's Avatar
Default Spots on rims
CAN ANY 1 HELP ME I HAVE THESE SPOTS ON MY FSPORT RIMS THAT WON'T COME OFF IT'S LIKE IT' WENT THREW THE PAINT DOES ANY 1 KNOW WHAT MIGHT HAVE CAUSED IT AND HOW I CAN FIX IT ??
Old 07-12-17, 03:07 AM
twixx007
twixx007's Avatar
I have this very same issue with my OEM wheels too. Not sure how to get these "stains" removed other than to maybe have the wheels refinished.
Old 07-12-17, 10:00 AM
Crossxup11
Crossxup11's Avatar
I bought a can recently. Duplicolor atomic silver is the one you want. When I get home I'll provide the actual part number. Its like a 99% match.
Old 07-12-17, 10:02 AM
Crossxup11
Crossxup11's Avatar
Also, those stains^^^
are from a tire cleaner. Be careful what you use! it strips the protective layer off your rims and burns a a black streak in.
Juts use soapy water to clean and a glossy finish for the tire wall if you want.
Old 07-19-18, 11:50 AM
LouisV
LouisV's Avatar
did you get this sorted?
1Lieutenant
02-27-21 05:58 AM
RYM
ES - 6th Gen (2013-2018)
04-29-18 01:54 PM
snabbledab
07-08-17 11:05 PM
davyjordi
08-04-16 04:52 PM
JDW379
06-02-14 07:21 PM
Quick Reply: F Sport wheels - touch up paint ??
