LC 500 - First Maintenance visit to the dealer (What do they cover)
Won't take too long. I'll be up and down the East Coast from FL to VA to NY area for the break-in period, so it'll be quick. After 10K, then I would only use it for fun of driving & warmer weather only.
I am at 570 miles now as of this morning. Taking the motorcycle route and will do the first change mysel at 600 miles. Then take it into the dealership at 5,000. Ordered everything I need except for the dino-oil which I will pick up today at the Toyota dealership. After the first oil change, I'll put it into Sport+ manual and take it up to 5,000 RPM. Will redline it after the second oil change at the dealership at 10k miles. This is just a personal method of breaking in the engine for performance and trouble-free longivity. My bespoke edition does appear to have an oil cooler installed so should be fine.
Finally switch to full synthetic at 15K miles.
Full synthetic or not is a personal things and many have different opinions on this. It's largely due to the cost and the question of necessity given the oil change intervals. Some feel a synthetic blend is just as good, others don't. It's a personal thing. I for one only use full synthetic (mobile 1) after the full break-in period. It just makes me feel better, which means 'Marketing' is working on suckers like me
Thanks. This shop is big on OEM so they tend to frown on anything else. I will discuss it with them tomorrow. I drove the car 5K miles in a year and it sits most of the time in winter. I do run it hard when I drive it so I want what is best for it.
asong1 (01-03-24)
asong1 (01-03-24)
Here is the best video for oil change (Japan) (Use Translated Captions): Apparantly Japan made filters sold in Japan comes with the drain plug. I've asked my local lexus dealer about this, acording to him, he has never seent his in the US sold OEM filters. Not that I would use it, but makes me wonder why it's different here...
This video is pretty detailed. Guy takes in his LC at 600miles to do a thorough check up with an independent mechanic, and collect samples from every component that has oil to be analyzed. Also inspects exhaust bolts, etc.., Most detailed look at LC 500 @ 600 miles (1000KM), shows the condition, sludges, etc..., Makes me think twice about my diff oil.. I may do a diff / transmission oil change at 10K, as part of the break in process going forward based on what I'm seeing here. To each's own.
asong1 (01-04-24)
Make sure to check oil level after dealer replaced oil. In my case I see they overfill it twice already. I had to remove almost a quart to bring it to the level indicated on a deep stick. It looks like instead of 9.1 they just put 10 and call it done.
sajack (01-05-24)
Break-in
Do exactly what the owner’s manual says and get your servicing at the dealer while the car is under warranty.
If your car requires 0W20 motor oil as my Lexus does, all 0W20 is full synthetic.
If Lexus thought your car needed a “break -in” oil change, they would say so.
Modern engines and modern lubricants, quit worrying and start enjoying your car and stay out from under the hood. Every time a nut is loosened on a car there is a potential for a problem.
The following 3 users liked this post by sajack:
Sounds to me like either your oil didnt drain all the way for some reason, or the mechanic was neglegent. If you didn't check it, it could've been bad..
