Perfect little charging tray for center console
4th Gear
Heya all - I found the perfect little charging tray to go in the center console if you (like me) don't want to be tempted to look at your phone. This works great if you have the '24 model with wireless CarPlay and AndroidAuto...
It is rubberized and has a short integrated USB C cable - AND it has a raised magnetic (magsafe) center so that the camera bump is lifted off the panel - $22 but for me totally worth it!
In this pic I used 2 little 3M command strips to affix it - and the 30cm cable is just the right length to feed back under it and plug in!
Badhobz (02-23-24)
not bad! but i got a feeling it'll slide around once you take a corner
4th Gear
Oh yes! - to counter act that I put 3M command strips (sort of industrial strength velcro meant for hanging paintings) on the bottom - and the tray itself has magsafe in the square that holds a magsafe compatible phone firmly on the charger.
Badhobz (02-24-24)
Brilliant! i might do the same for mine. Although i usually just plug it in to get apple car play and it charges anyway
mariog7
ES - 7th Gen (2019-present)
01-16-22 06:42 AM
pokerbud81
09-24-19 03:09 PM
