Trunk Carpet Resolution
Old 03-10-24 | 08:47 PM
blisguy's Avatar
blisguy
Default Trunk Carpet Resolution
Since the 24 LC500 now has tires that are not run flats, they added a tire repair kit. My dealer says that Lexus is aware of this problem. It's been 6 months and I haven't heard of how Lexus is going to resolve this
What should they do?
Old 03-10-24 | 09:06 PM
woodranch's Avatar
woodranch
Great call blisguy, I agree, not the best fit!
Old 03-10-24 | 09:49 PM
NiceCars's Avatar
NiceCars
Can the flap be placed under the kit or down along side it?
Or can you temp relocate the kit?
Old 03-11-24 | 06:29 AM
blisguy's Avatar
blisguy
The straps are bolted to the underfloor. There are no velcro attachments. The kit's too heavy for velcro.
I've turned the carpet rubber side up because the carpet should be reversed since the extension of carpet should be on the passenger side.
Old 03-11-24 | 07:55 AM
kirkd1's Avatar
kirkd1
So much for planning ahead and attention to detail. I ask about this when at the dealer picking mine up. I should have just pulled it and left it with the dealer and requested replacement when and if available. This is a good example of throw it in there they won't notice. This would look ridiculous on a Camry much less an LC. I did not get a jack, lug wrench or other tools, but I did get an ill-fitting carpet and a scredriver!
Old 03-11-24 | 08:11 AM
kirkd1's Avatar
kirkd1
Upon further review the Lexus page states, Does not fit 2024.
Old 04-16-24 | 01:37 PM
jdz71's Avatar
jdz71
4th Gear
I bought the rubber trunk mat as I thought it seemed to cover more on the right side (with a slot to accommodate the first aid kit strap. However, similar issue on the left side to the carpet trunk mat (reported above) where it did not fit the new tire repair kit and strap. I ended up measuring where the strap would come through the rubber mat, and used an xacto knife to cut a small slit so the strap could feed through. Now the trunk mat sits flat and the tire repair kit straps in on top. Wouldn't work so well for a carpet trunk mat, but it was an acceptable solution (to me) for the rubber mat.
2959 (04-16-24)
Old 04-16-24 | 02:17 PM
NiceCars's Avatar
NiceCars
The latest 24s coming in I’ve seen don’t have the mat added as an accsy/option so they may have finally realized they don’t fit.
Old 04-16-24 | 03:40 PM
kirkd1's Avatar
kirkd1
Sounds like an excellent solution to the problem. I am waiting to see if Lexus will provide the proper fitting carpet or just refund my money.
bob123
11-04-17 06:47 PM
CrazyChino
NX - 1st Gen (2015-2021)
04-26-17 04:25 PM
ral2531
03-26-15 01:24 PM
SC3coupe
08-01-12 03:53 PM
rodel
01-09-04 09:48 PM
