aftermarket wheel question
Old 04-20-24 | 07:04 AM
Barncobob's Avatar
Barncobob
Default aftermarket wheel question
24 LC 21" wheels stock front 8.5 rear 9.5
aftermarket front 9.0 rear 10.5
do the wider rims affect the tire front being 1/2" wider and rears a whole 1"
Old 04-20-24 | 07:08 AM
Badhobz's Avatar
Badhobz
Basically are you asking if the stock tires will fit on those rims ? Yes they should.
just be careful of the offset. +20mm offset allows you to clear the huge brake Calipers. Anything lower might cause issues.
Old 04-20-24 | 12:29 PM
flowrider's Avatar
flowrider
My Vossen wheels are 9½" wide in front and 10½" out back. My offsets are +5 in front and +15 rear. I'm running 255/40/19 and 295/35/19 in back.
As far as stock tires fitting the wheel widths you are suggesting - Yes, 245/40/19 and 275/35/19 fall within the range to fit those wheels.
Lou
Old 04-20-24 | 12:40 PM
Barncobob's Avatar
Barncobob
Thank you, its right there black and white,,,as long as I stay stock offsets 25 I should be good to go..these 24 rims are fugly. Looking at the Avantgarde M520R dark graphite, car is 24 Cloudburst grey..Any comments + or - are appreciated.
Old 04-20-24 | 05:39 PM
IS_250's Avatar
IS_250
if you are purchasing aftermarket wheels, have the vendor spec it out for you. Typically they wont have the same exact offset with aftermarket wheels but they should get your fitment correct so it clears the brakes and fits the car correctly.
Old 04-20-24 | 08:24 PM
flowrider's Avatar
flowrider
^^^^Apparently those wheels are available in two widths for the staggered 21" setup for the LC. The offset and bolt pattern seems to be the customers choice:
https://getyourwheels.com/product/46...exus|844|LC500
Lou
Old 04-21-24 | 11:55 PM
Meraki Autoworks's Avatar
Meraki Autoworks
Your #1 Lexus Vendor
We can get you taken care of with Avant Garde wheels, we are an authorized dealer. Feel free to text or message us and we can get you setup.
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Barncobob
03-14-24 11:36 AM
ssmoked
RC F (2015-present)
28
09-11-16 11:26 AM
datplayaz
02-26-12 09:46 AM
jonjon6228
01-03-12 07:19 PM
blaznsc4
Wheels, Tires & Brakes Forum
09-06-05 02:37 AM
