Max fuel range
#61
Summarize all answers above about ethanol containing fuel I can say there is definitely a big problem for lawn equipment.
now if we move it to our car what would be the best?
we don’t have carburetors like lawn equipment and the only component is a tank and fuel lines.
for winterizing our cars for winter we need to remove any gasoline contains ethanol and keep the tank 100% full to remove air as much as possible from the tank.
any other hints?
any other hints?
#63
Just to see...
Ok I'll just preface this by saying it took way too much discipline, patience, and effort and I will probably never do this again, but...
I just wrapped up basically a normal amount of driving I'd do through one tank of fuel, 100% on ECO and 100% keeping the eco throttle gauge under the white line. This basically means a rev cap of 2k RPM (only went to 3k RPM once when I misjudged when a red light turned green as I made a right turn, and I didn't want to royally **** off the cars coming through the intersection by cutting them off then being a snail).
- Over 320 miles I have a tank average of 21.1 MPG. This is mostly local suburban driving at varying speeds between 15-60mph with lots of traffic lights, school zones, some amount of idling while picking up kids as well. When I did take it on the highway for brief stints I kept it under 75mph. I still have a little over 1/4 tank of fuel left per the gauge, which means likely 6-7 actual gallons of fuel extrapolated to 450+ miles on this tank of gas if I were to see it through. I don't have a max "range" reading because this was only one tank of fuel and the computer doesn't adjust that quickly on fill-up.
- In my normal driving, which is the same type of driving conditions but involves me doing lots of paddle downshifting, bursts of acceleration basically using 2k RPM as a floor instead of ceiling, some tinkering in Sport+, and highway speeds that hover between 85-90mph, I get 16-17mpg.
This was just an exercise to see what the car can do if driven with an extreme featherweight foot in the most economical way I know how to drive. I got 30% more mpg than I typically would get..that would save me $20 in gas per tank if I ever need to pinch the wallet I guess.
One day I may do a similar exercise on a road trip, but I think more people have done that and shown the car gets over 30mpg if you really just cruise for 600 miles at 70mph on a single tank. I hadn't seen it done for more of a city driving exercise so I gave it a go, and I'll never be doing it again.
It begs the question...should I try the other end of the spectrum and see how low I can go?
2959 (09-11-24)
np20412 (09-11-24)
