Paint Correct at 500 miles
I can certainly see why you did it on your iSF, but why on your LC![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
https://www.clublexus.com/forums/is-...orrection.html
Lou
Lou
Oilman (04-09-18)
I think what some of you may be referring to is called a buff not paint or color correction. What we use to call "Spiderwebs" in Paint/Body shops years ago is light little streaks in the shape of spiderwebs on the clear coat from micro abrasions left after wiping with cotton type clothes. Those are easily buffed out using a high speed polisher with a foam pad and a light swirl remover (polish). Can be done in a one-step process followed by a good wax to seal afterwards. A paint or color correction would require color sanding the clear coat or a repaint of the clear or the clear and the paint both.
Have 25 years in automotive washing, detailing and paint/body. I hope that clears a few things up for some of you.
Oilman (04-10-18)
I had a gentleman help me, you can find more of his work here
https://www.instagram.com/international_auto_studios/
He's part of the F Crew we have here in Houston too
It's a multi stage process and finished off with cquartz
It is caviar
flowrider - the LC from factory was 95 to 99% light return, now it's 100%
It is caviar
Oilman (04-10-18)
Very nice! Like many, when I took delivery of mine I identified more than 15 scratches on the paint, most very light . A dozen or so hours of loving labour later (including a few areas requiring low grit sanding), the paint was brought up to Pebble Beach standards. All of my other cars went through the same process, even the Lambo so Lexus is no exception.
